Install Wood Tile
4,582
45
4
Published
Introduction: Install Wood Tile
About: Hey everyone! My name is Beau. I'm a father, a diy lover, and a partner in a construction company. I started learning the construction business at a young age. My dad, brother, and 3 uncles are all general c...
Hey Everyone! A little tile project at my friend's house on the second story. It was two rooms that are 12 x 10. We started with the carpet, baseboards, and all doors removed. Hope you enjoy and make sure to follow.
Step 1: Tools and Equipment
Here is a list of the tools and supplies that are needed for the job. I used a grinder instead of a tile saw because it worked for this project.
Tools:
Margin Trowel
Notched trowel
Pencil
Duct Tape
Grinder with diamond tip blade
Thin-Set mixing paddle
Drill
Level (2 and 4 foot)
Ruler
2 Buckets
Sponge
Supplies:
Drywall Nails (size: 6 x 1 5/8)
Thin-Set
Grout
Cement Board
Water
Step 2: Installing Cement Board
We are installing on the second floor so, we need to install cement boards.
1. Place the cement boards on ground off centered. Try to place the boards to cover the maximum amount of area.
2. Screw drywall nails at each corner of each board. Place screws every 6 to 8 inches on the edges and through out the board.
Step 3: Cement Boards Part 2
To finish installing our cement boards, we need to install our cuts and tape the joints.
1. Measure from the cement board to the wall. Mark and cut your cement board using a grinder with a diamond tip blade.
2. Install your cuts with your drywall screws. Ensure you get each corner and around the boarder.
3. Once all your cuts are installed, you'll need to duct tape the joints. Use duct tape and make sure it's kind of flat.
*TIP: If you have long cuts then you can use your 4 foot level as a straight edge.
Step 4: Firguring Your Layout
This is the hard part. You need to figure out how the tile will be laid. We decided to have a joint running down the center of the door. We also decided to have a slight slope downward, so we wouldn't use to much Thin-Set. Just remember these hints:
1. Which direction will the tile go?
2. Where do the joints need to be?
3. How much slope, if any, would I like?
4. Any obstacles that can mess up your lay?
Step 5: Making Your Thin-Set
We used MultiSet 50 lb. Modified Thin-Set Mortar.
1. Cut open and place the Thin-Set in a bucket.
2. Add water and mix with a Thin-Set mixing paddle.
3. Add more Thin-Set or water as needed till your Thin-Set looks like paste.
4. Fill your second bucket up with water and clean the paddle in the bucket. it makes for easy cleaning.
Step 6: Laying the Tile
Take your time and make sure to get flushed tile.
1. Place the Thin-Set on the ground or on the back of your tile. Next, notch the mud with your notched trowel. Clean the side of the tile, so Thin-Set doesn't get inbetween the tile.
2. Give light pressure and shimmy the tile back and forth. This will remove some of the mud from underneath and lower your tile.
3. Lift the tile up and add mud if needed.
4. Place your level across to ensure that all your tile is touching the bottom of your level. This will show you that the tile are flushed at the angle your achieving. The angle of the room should be pretty close to almost even.
5. Repeat
*You want your tile pretty flushed, but grout will help cover up most of the edges. So, don't worry if you're slightly off.
Step 7: Cutting Tile
You'll be doing cuts through the entire project. Your project may even start with cuts.
1. Mark from the tile to the wall. If you are placing baseboards down then your cut has to be pretty close. However, if you're not placing baseboards then your cuts have to be exact.
2. Use a tile saw to make your cuts. However, if you dont have one then you can use a grinder with a diamond tip blade that has smooth smooth edges. I only recommend this if you can hide the edges of your tile under the baseboard.
3. Mark and cut your tile the same way you did with the cement board.
4. Repeat till all cuts are made.
Step 8: Grouting
Let your Thin-Set dry for 24 hours. Now it's time to add the grout.
1. Make the grout the same way you would your Thin-Set. You're going to want it pretty wet for thin joints.
2. Place a scoop of wet grout on the ground. Use a grout float to push the grout into the joints.
3. When the grout dries up then place back into the buck and mix.
4.Let the grout dry till you get a slight white shade on the tile. Should take around half a hour.
Step 9: Clean the Grout
Final step is to clean the grout.
1. Once the grout is dry or close to dry then get a sponge with water.
2. Use a slightly moist sponge and clean the faces of the tile.
3. Hit the joints lightly to smooth them out.
4. Look for holes in the joint and fill with leftover grout. Just use your finger to smooth it out then hit it lightly with the sponge again.
5. Repeat 3 times.
6. Use a dry towel to get rid of any left over grout.
Step 10: That's It!
Put on your baseboards and call it another successful project. You now have awesome looking tile in your home. It was a fun project and if you have any questions then just send me a message or leave a comment.
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    4 Comments
    First time I ever heard of anyone deliberately creating a slope in a floor.
    In one room, I had to slope the room up slightly because if I did it perfectly level then I wouldn't be able to get Thin-Set underneath the tile. The flooring on the second floor was pretty bad.
    In the other room, the flooring was very low compared the existing hallway tile. So, to save money, I put a downward slope to decrease the amount of Thin-Set I had to use. Also, the second floor didn't needed the added weight from all that Thin-Set.
    The slopes were very mild, but essential. It's just another thing to take into consideration because you don't want to lay all that tile and find out that being level across cost you time and money. You can't notice the slopes when you walk on it, but you do notice it when you're actually tiling.
    One tip...if I may: as you have a small roim would be better to lay the tiles perpendicular with the door, the long side design would give impression of a larger room. As you've set the tiles the first impression is as cutting up space, making the room look even smaller.
    And another one... usually is better to start from the far distant corner of the room toward the door so you can escape clean while laying the tiles.
    Nice design anyway! I love the final look!
    Excellent instructable! Laying tile is a lot of work, but it's a pretty approachable DIY project. Thank you sharing a great write-up on the process :)
