Install Zan/Voxel/Rei's Minimap Minecraft 1.7.10 [EASY]
211,322
16
45
Posted
Introduction: Install Zan/Voxel/Rei's Minimap Minecraft 1.7.10 [EASY]
Just to let everyone know, Voxelmap is the new version of Rei's Minimap and Zan's Minimap. The other mods still exist, byt they are not updated for the newest minecraft version. This mod will work on any server or single-player world, if you have cheats enabled in single-player or if you have the permission to use the /tp command on servers. In this guide I will be showing you how to install Voxelmap on Minecraft 1.7.10 with the required software. Links for downloads are included. Everyone should be able to follow all the steps. High-Quality screenshots will make sure you can understand what I am doing.
Step 1: Going to the Profile Manager Tab
Click on the 'Profile Manager' tab in your Minecraft Launcher.
Step 2: Creating a New Profile
Right-click anywhere inside the profile manager window and select the 'New profile' option.
Step 3: Configuring the New Profile
In the window that pops up, make sure that the minecraft version is set to 'release 1.7.10'. If not, select the option from the drop down menu.
Step 4: Saving the Profile
To save your profile, click on the 'Save' button in the bottom-right corner.
Step 5: Selecting Your Profile
In order to select the profile you have just created, click on the dropdown menu and select your new profile. If you forgot the name, you can go back to the profile manager window and find your new profile in the list. Then you can select the right one in the dropdown menu as shown in the picture.
Step 6: Checking Your Minecraft Version
If you followed the previous steps correctly, you should see that you are running Minecraft 1.7.10 when you press the play button. If not, go back to the previous steps and try again.
Step 7: Downloading the Liteloader Installer
Liteloader is another mod that is needed in order to run Voxelmap. This means that if you do not install Liteloader, your Voxelmap won't work. You can download the Liteloader installer from the official Website: http://www.liteloader.com/download Make sure that you download the 1.7.10 EXE version!
Step 8: Installing Liteloader
To install Liteloader, run the file you have downloaded in the previous step. By default it will be saved in your Downloads folder. Run the file by double clicking on it or right click on it and select 'Run' or 'Open'.
Step 9: Installing Liteloader Into Minecraft
In the installer window, select the 'Install Liteloader (reccomended)' option. and then hit the 'Ok' button.
Step 10: Confirming the Installation
When you have pressed the 'Ok' button, wait for the installation to finish. When the installation has been completed successfully, the following message will show up. You can press the 'Ok' button to close it.
Step 11: Downloading Voxelmap
Before installing voxelmap, you need to download the mod itself. You can download it from the following website: http://www.mediafire.com/download/b5e5kfden8o55lc/mod_voxelMap_1.2.0_for_1.7.10.litemod You need to press the download button to download voxelmap.
Step 12: Navigating to the Mods Folder
Now you need to go to the folder where you will be installing Voxelmap. To do this, you press the windows start button and type %appdata% and then press enter (Win 7 and Vista), or you hold down the windows key and R on your keyboard at the same time and type %appdata% in the box that shows up and press the 'Ok' or 'Run' button.
Step 13: Selecting the .minecraft Folder
In the Windows Explorer window that shows up, you want to open the .minecraft folder by double clicking it or right clicking it and pressing the 'Open' button.
Step 14: Selecting/creating the Mods Folder
You are now in your Minecraft folder. Here all you minecraft data is stored, so be careful and don't mess with anything, unless you know what you are doing. Since we do know what we are knowing, we can just continue. Open the mods folder, or create one by right clicking and pressing the 'New' tab and selecting 'Folder' in the menu that shows up.
Step 15: Installing Voxelmap
In the mods folder you want to paste the Voxelmap file you have downloaded in the previous steps. The voxelmap file will be saved in your downloads folder by default if you lost it. You can always download it again if you really lost it. You can do this by going back to the previous steps.
Step 16: Selecting/creating the Voxelmap Profile
In order to activate Voxelmap, we need to select the right profile. Simply select the 'Liteloader 1.7.10' profile in the list or create one. If there is no Liteloader profile in the list, you need to create one. You can do this by simply pressing the 'New profile' button. In the window that shows up you need to name your Liteloader profile (I named it Liteloader) and select 'release 1.7.10-liteloader1.7.10'. Then you can save your profile. Make sure you select your newly created Liteloader profile when starting minecraft!
Step 17: Testing Your Voxelmap
When starting Minecraft (with the correct profile) and playing on a world, you will see the welcome message and the voxelmap on your screen! This means you have installed Voxelmap Correctly! Press the M key to open the Voxelmap menu!
  • Minecraft Challenge 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Sew Warm Contest 2018
44 Comments
Wait. So you DON'T put it in the 1.7.10 folder? If so, WHY AM I SO STUPID!
What do you mean by 'it'? And we all make errors some times XD
Can you have Forge and LiteLoader running at the same time because I have other mods which runs on Forge...
It says forge not detected when i ry downloading it with forge...?
You need to install Liteloader, not Forge. This mod is make to work with Liteloader instead of Forge. Please follow the instructions in the guide for more detailed information.
yeah i'm trying to install a minimap of some sort to regrowth in the FTB launcher and I can't find a way to get this to work some help please
Installing the shaders mod is an entire different subject. If you want to know how to do this, then I'll get to work on making a tutorial for that.
i downloaded the liteloader installer and it merged my liteloader with my forge it auto named to profile (LiteLoader 1.7.10 with Forge 10. 13.2.126) i would also like help on installing the shaders mod
I have forge and liteloader installed. I have 2 profile called forge and liteloader automatically installed by the software other than my usual. I run it on 1.7.10 Forge. All my mods run fine on this except this minimap mod. Its in my mods folder. How can i enable this mod?
