Just to put things into perspective, the average electric clothes dryer needs 4kw/hour to run. If you run the dryer on a daily basis for 1 hour a day, depending on the cost of electricity, you will be throwing out close to 30$ a month just to dry your favorite shirts! That's well over 300$ a year. And just imagine when you dry bed sheets often and baby clothes almost daily.
Since according to scientists (IntelIntel), generating 1 Kilowatt Hour of power also generates 1.64 lbs of carbon dioxide, a clothesline is cheap way to help the planet. (One hour of clothes drying generates about 6.56 lbs of carbon.)
But whether or not you believe the planet is warming abnormally is beyond the point. Saving your hard earned money is reason enough to put up a clothesline.
But first, you must decide where to put your clothesline. Locate it at a place that's easy to reach. Take into account that you will drop a few pieces of clothing over the years. So make sure you can go and pick them up. Clothes also dry a lot faster in a sunny location. The photons that the sun emits actually give energy to the water molecules so they get "kicked out". So sunny locations are preferable. If you can't do that, choose a place that is either windy or very dry. Clothes can also dry in the basement during the Winter when the house is dry. As an added bonus, drying clothes inside a dry house raises the humidity level.
Selecting the right clothespins is also important. Some have very weak springs and will surely have a hard time holding your clothes. Spending a bit more on good pins is a good investment.
Remove these ads by
Signing UpStep 1Required Materials
2 large hooks
2 pulleys
1 length of plastic covered clothesline wire
1 line tension adjustment spool
metal anchoring slugs (if you have masonry or brick walls)
Tools:
1 Electric drill
1 large screwdriver (helps in screwing the large hooks)
1 hammer (to drive the anchors in)
1 wire cutter
1 ladder
I was lucky that most of the work was done when I bought the house. As you can see, I have a more sophisticated setup than the one I described. But it still does the same thing.
I'm sorry I don't have a set of "work in progress" pictures.
When I did the research for the article, I checked out the Energy Star website where they claim no clothes dryers have the rating simply because there is almost no difference between the efficiency of all models.
"ENERGY STAR does not label clothes dryers since there is little difference in the energy use between models."
A clothes dryer is basically a tumbling drum with a fan and heating coil. The only way I can see to make a more efficient model would be to use a refrigeration based dehumidifier... then again it might not be as efficient in the end since it would take a lot of time to dry the clothes.
