loading
Step 4: ...Installing the Fan...
This is the easiest step, 4 screws and you're done!
I chose to use a Sunon MagLev Dual 40MM Case Fan KDE1204PFV2 because I happened to have it lying around...
Allign your fan with the part of the case where you removed the plastic from the inside,put it up against the 6th piece of plastic which you did not remove. Stickers facing inwards.
Allign the screw holes with the vents to make things simple just put the screws into the vent holes, or if you're feeling ambitious you can drill your own.
I did this with two fans on either side of the case - pretty much in the same area you have yours. I used a 4 pin molex adapter tog et power from the hard drive power connector. Nice job on the header though.
About This Instructable
9,891views
7favorites
License:
Bio: I consider myself a professional student. I love learning new and challenging things, which is what brought me to instructables - lots of things to learn ... More »
More by mutantpoptart:Semi-Wireless Headphones CRYO-DOMO My Space
Add instructable to:
