iImage Information
This instructable tells u how to install apps on ur Iphone/Ipod Touch WITHOUT wifi ..!
Step 1Requirements!
iImage Information
So you're staring at a newly jailbroken iPhone or iPod touch, and you're ready to install some of the best applications out there ... but you lack a strong Wi-Fi connection. iGopher, a free application for Windows, lets you download and compile all the third-party apps you want on a connected computer and then transfer and install them to your freed iPhone/iPod touch through your regular USB connection.
Requirements
1. A JAILBROKEN Iphone/Ipod touch...lol
2. A PC
3. Iphone/Ipod touch usb cable
4. iGopher (You can download it from here (ITS FREE! ) :
http://igopher.googlecode.com/files/Gopher_2003.0.2.zip5. Internet connection in ur PC (no need of wifi )
but change the ipod photo to 4gen
That's most probably the source of the problem, some methods like ZiPhone don't allow
USB access to the entire iPhone filesystem. Check if you can see the root directory
with a tool like T-PoT, iPhoneList or iPhoneBrowser.
You need to modify your services.plist in /System/Library/Lockdown/
STEPS:
DOWNLOAD modified services.plist from here http://independence.googlecode.com/issues/attachment?aid=-4518899572723920387&name=Services.plist
Check if you can get into /System/Library/Lockdown/
with Total commander or iPhoneList or iPhoneBrowser.
If you can,follow these steps
1.Rename services.plist to bservices.plist (backing up)
2.Copy the downloaded services.plist file to /System/Library/Lockdown/
RESTART IPOD.
If you cant get into /System/Library/Lockdown/ through Total Commander ,follow these steps.
1.Create a 'Documents' folder in your desktop.Copy the downloaded services.plist
2.Copy this Documents folder to your ipod touch (where you can access through total commander)
3.Make sure you have MobileFinder downloaded to your iPod.(which is available in the installer or download it manually if you don't have wi-fi)
4.Open Finder.Goto top right corner and click on ~ button
5.You should see Documents Folder ,open it.
6.Copy Services.plist
7.Goto /System/Library/Lockdown/
8.Rename Services.plist (original file which you find in /System/Library/Lockdown/ ,NOT THE DOWNLOADED ONE) to BServices.plist
9.paste your downloaded Services.plist there
10.Reboot Ipod.
Hope this will help.
i get to run the gopher application and select the apps that i want for my ipod touch .. but when i click on export this is what it says .
"Script and files ready, saved in export directory.
No valid connection, no transfer will be performed at this time.
can you solve this problem?? .. thanks in advance '
