3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Install system 7.0 software on a classic mac using a pc (and a lot of other junk)
So here is the scenario, I have an idea for a project, that project needs a classic Macintosh computer, so I picked a couple 68k compact macs from the local recyclers for a dollar each (ones really dead, atm) the one that functions is a Macintosh SE, with a dead hard disk and a funky 800k floppy disk
With no other working Mac's in the house how do I get this thing to boot??
In the following instructable I will show you how to do it using a apple formatted and apple  firmware installed hard disk, a pc running ubuntu, a pc SCSI card, and a emulator so you can transfer the hard drive to a Macintosh SE and have it boot
This is a narrowly focused instructable that should apply to any classic Macintosh with a SCSI hard disk and that can run system 7.0 but I have no way to test it so run wild with it
Also you can use this information to take a hard disk out of a failed computer and retrieve information off of that disk (as long as the hard disk is still ok)
This instructable also gets sorta complicated, it requires specific things and software, but it is much better than the alternative in this case, which is 800k floppy disk drive (dont have another mac) apple firmware SCSI cd rom (dont have), or have "someone" snail mail me a floppy disk (bah!)
So if you are still with me ... shall we?
Step 1Requirements
Requirements
Hardware:
one working HFS or HFS+ formatted SCSI hard disk with apple firmware
one Macintosh computer with a SCSI interface (target) capable of running system 7
one pc with linux installed and SCSI interface (host)
What I used:
80MB hard disk out of my dead performa, it would boot but was just a minimal install to only work on the performa 200 / classic 2, so my SE would halt
Macintosh SE, 800k floppy so I could not just make a boot disk, if your computer has a "super disk" you can just download image files on your pc and make floppy boot disks, 800k disks require a different drive mechinism that IBM heritage pc's do not support
A amd X64 running ubuntu 9.10, and a compaq scsi card, yes you probably can use other flavours of nix, but that is out of the scope of this article
Software:
Ubuntu linux www.ubuntu.com/
Basilisk II  (apt - get)
Sytem7.0.smi.bin  download.info.apple.com/Apple_Support_Area/Apple_Software_Updates/English-North_American/Macintosh/System/Older_System/System_7.0.x/
Basilisk II starter disk www.emaculation.com/articles/starterdisk.zip
Basilisk II compatible rom, these rom images can only come from a mac you own, course if you can not boot how can you get them?? I googled some shady looking sites and finally found a rom image for a "performa" which works fine with the emulator
I am going to link it here unless instructables says something, only with the understanding that you are only going to use it to bootstrap your real physical classic Macintosh computer, and not just leech it for emulator usage, if you do its your own butt, I claim no responsibility for the use of this outside of booting your machine
6 comments
Sep 5, 2011. 11:41 PMmarkitzero says:
I have a SE/30 how the Heck do you get those things apart because I need to Change out the HardDrive i have another one to change out with another SCSI Drive.
Aug 18, 2010. 2:08 PMKasm279 says:
I have an SE too, but mine has the dual 800k drives instead of an internal SCSI disk. I did get an external SCSI hard drive though, and I plugged that into my PowerMac G3 All-In-One (the bridge between the older comps and the newer ones) and installed that way (running OS9 on the G3)
Jul 15, 2010. 7:23 AMchandler104 says:
How did you get them from the recyclers? Do they sell them? I have a project too and need one of these! Ebay is wayyy tooooo expensive!
Jun 24, 2010. 7:15 PMzack247 says:
ver detailed and well documented! this is some good information, even though i use pc's, this will be some handy info for future reference
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
57
Author:osgeld
