These small 12V 5mm LEDs pack an incredible punch of light, and effortlessly cycle / fade through multiple colors without the need for an RGB Controller.
Also, with polarity protection and a built in resistor on board, these RGB Color Changing LED Lights are truly a plug-and-play lighting solution right out of the box! Simply plug the positive and negative terminals to any 12V source, and your LED project is DONE.
Suggestions for uses of Oznium's Automatic Color Fading LED Lighting Modules:
- Home Accent Lighting
- Interior Accent and Project LED Lighting
- Casino Lighting & Retail Establishment Lighting
- Bar / Pub LED Lighting for an amazing LED effect
- Automotive LED Lighting
- Interior LED Decoration
- Frosted Item Project Backlighting
- RV LED Lighting
- Stage and Band LED Lights
Remove these ads by
Signing UpStep 1Bundling the RGB Color Changing LEDs Together
You can always test the angles once they're inside your project (before permanently mounting them) and move them / spread and secure them in any way that suits your project.
Since I chose to mount the 3 RGB Color Changing LEDs into a Salt Crystal Lamp that had a tube like chamber and previously used incandescent lighting; I chose to mount them on a wooden brace and fan them out only slightly to fully fill the full crystal lamp with a brilliant cast of light.
Thanks!
Fixed.
-Kris
http://www.instructables.com/id/Installing-12V-Color-Changing-RGB-Lighting/
