Installing Board and Batten Wainscoting
3,690
22
Posted in WorkshopHome-improvement
Introduction: Installing Board and Batten Wainscoting
About: I run FixThisBuildThat.com where we focus on Woodworking and DIY Projects, Plans and Tools. Come check us out and let us inspire you to build something awesome!
In this Instructable I'll show you how to install some board and batten wainscoting Hope you enjoy the project!
Be sure to watch the video above, and if you like it please subscribe to my YouTube channel!
You can also see a more detailed blog post where a FREE SketchUp file is available at: http://fixthisbuildthat.com/how-to-install-wainscoting-diy-board-and-batten/
Step 1: Gather Tools and Materials
Here are the tools and materials I used for this project. I've provided affiliate links for your convenience.
Tools Used
Materials/Supplies
Step 2: Prep and Paint Walls
I started with this drab looking room..ugh.
First thing I needed to do was paint. I laid out a line for where the top rail would go at 36".
I painted the entire room above the line a nice blue green (Behr Clear Pond).
On the lower portion I painted it the same white I will be painting the trim pieces. In the corner I used green painters tape to get a clean line.
Step 3: Remove and Replace Base Boards
I removed all the old base boards and measured the room for the replacements.
I'm using 3/4" MDF for all the trim parts and cut the long rails out of a 4x8 sheet. The baseboards are 5-1/2" tall and all other trim is 3-1/2" except the cap rail.
I trimmed the baseboards and upper rail to size and mitered the baseboards as needed.
I dry fit and measured everything then went back to the shop.
Step 4: Prep the Trim for Install
Since the wall was 10' long I had to join a small piece of board to the long wall baseboard and rails.
I used pocket holes for the joinery, but these are still very frail so be careful.
To prep for paint I spackled the joints between the boards.
I also covered all the edges with spackle so the paint would lay on smooth and not soak into the fibrous edges.
I finished prepping by priming all the trim pieces.
Step 5: Install Baseboards and Top Rail
I installed the mitered baseboards around the room using 2" brad nails. I leveled the baseboards for a consistent flow around the walls.
I made another level line on the wall to reference the top rail. I nailed the top rail in using 2" brad nails as well.
Step 6: Cut and Install the Batten Boards and Cap Rail
I used a SketchUp Model to draw up a few options for how many battens we wanted and the proper spacing.
After settling on what we wanted I laid in my vertical battens (which I had cut long before priming) and marked them to the size needed and made the cuts back in the shop.
I installed the vertical battens with 2" brad nails after cutting to size.
The final trim piece was adding an 1-1/2" cap rail for a little details.
Step 7: Finishing Touches
I finished up by caulking all the seams and spackling the nail holes.
Once dry I put on two coats of white paint.
The finished room turned out amazing!
If you liked it please subscribe to my YouTube channel!
You can also see a more detailed blog post with the SketchUp file at http://fixthisbuildthat.com/how-to-install-wainscoting-diy-board-and-batten/
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    2 Comments
    Just as you do, it seems easy. Great job.
    Great, simple project to spruce up a room. It's nice to see how simple it can be to do, thanks!
