Upgrading NodeMCU Firmware to V1.5 on EPS8266 (ESP-12E)
6,236
25
Posted in TechnologyArduino
Introduction: Upgrading NodeMCU Firmware to V1.5 on EPS8266 (ESP-12E)
I've been updating firmware on my NodeMCU few times without issues - at least up to 0.9
The installation procedure has changed with SDK 1.5 - I've spent few hours before I got it right, so maybe this post will help you to save some time.
Here you will find all required information, but depending on your chip manufacturer you will need different combination of some options, and this is exactly the part when it's getting a bit tricky.
Since things are changing rapidly, I will point out exact versions in this tutorial, so that it's clear what was working with what at time of this writing.
Step 1: Installing Esptool
Download esptool v1.1 https://github.com/themadinventor/esptool/releases/tag/v1.1 and unzip it.
This will give you possibility to execute esptool.py form command line - we will use it below.
Step 2: Determining Version of Your ESP8266 Chip
As usual there are different versions, and probably you will have to modify flashing commands if you have different one.
sudo python esptool.py -p /dev/tty.wchusbserial1410 flash_id</p><p>esptool.py v1.2-dev
Connecting...
Manufacturer: e0
Device: 4016
Well it's obviously ESP-12E with 4MB flash. How do you tell? I've no idea - just google for "Manufacturer: e0 Device: 4016" and check what people are thinking.
Step 3: Building Custom Firmware
Now we have to obtain firmware containing Lua interpreter for our chip - it's everything that you will need to upload Lua scripts over serial.
Basically you will need two binary files:
  • custom firmware - something like: nodemcu-dev-7-modules-2016-08-10-10-43-59-integer.bin
  • initial-data-block (esp_init_data_default.bin)
Obviously you will need matching versions.
There are two options to get those files:
  • you can download it from my github repo - this will give you SDK 1.5.4.1
  • you can also use cloud service to build latest release. The link to latest initial-data-block can be found here - just search for esp_init_data_default.bin
I would prefer a latest version - as usual. But in case of some problems you can try using version provided on my github repo. At least this one was working in my case with ESP-12E, this might help you to locale a problem.
Step 4: Erase Flash
Put your chip into flash mode as described here. If you have development board it should have two buttons: flash and reset. In such case press flash and without releasing it press reset, after that release reset.
Now you have to determine com port, and change it in all commands in this tutorial. In my case it's: /dev/tty.wchusbserial1410
Let's finally erase flash!
<p>sudo python esptool.py -p /dev/tty.wchusbserial1410 erase_flash<br>
esptool.py v1.1
Connecting...
Erasing flash (this may take a while)...</p>
Step 5: Flashing New Firmware
Put your chip again into flash mode.
I am assuming that you have in you current directory two binary files: one with firmware (nodemcu-dev-7-modules-2016-08-10-10-43-59-integer.bin) and second with init-stuff (esp_init_data_default.bin).
sudo python esptool.py -p /dev/tty.wchusbserial1410 write_flash -fm dio -fs 32m 0x000000 nodemcu-master-7-modules-2016-08-10-10-45-03-integer.bin 0x3fc000 esp_init_data_default.bin
esptool.py v1.1 Connecting... Running Cesanta flasher stub... Flash params set to 0x0240 Writing 385024 @ 0x0... 385024 (100 %) Wrote 385024 bytes at 0x0 in 33.4 seconds (92.2 kbit/s)... Writing 4096 @ 0x3fc000... 4096 (100 %) Wrote 4096 bytes at 0x3fc000 in 0.4 seconds (80.0 kbit/s)... Leaving...
Step 6: Testing....
I've used ESPlorer - it looks just fine :)
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    3 Comments
    Nice! Do you have a list of things that work better/worse with this firmware?
    I my case I was running low on RAM, after update there is more free RAM :)
    I did not notice any problems. Definitely new firmware uses less RAM - I think about 5kb in my case. I'm not exactly sure.
