Installing & Using Arduino IDE on a Raspberry Pi 3
5,957
14
Posted in TechnologyElectronics
Introduction: Installing & Using Arduino IDE on a Raspberry Pi 3
About: I also find myself busy with creative web design, my websites, motorcycling, photo shopping, micro electronics, non-commercialised music, superhero movies, bad ass series and many other things that are not i...
This Instructable will go through the easy steps in installing the latest version of the Adruino IDE on a Raspberry Pi.
The Arduino IDE is available for all the major operating systems, but will show how to install it on a Raspberry Pi 3 model B running Raspbian Jessie in the GUI. An active connection to the internet will be required and to get the full experience the Raspberry Pi also needs to be connected to a screen, keyboard and mouse.
Step 1: Installing the Required Packages
The easiest way to install packages is from the terminal.
To make sure Raspbian Jessie is up to date use:
sudo apt-get update
sudo apt-get upgrade
Install Arduino IDE with:
sudo apt-get install arduino
Step 2: Connect the Arduino
After connecting a Arduino board to the Raspberry Pi using the appropriate cable, pull down the Raspbian main Menu and select Arduino IDE under Electronics. It will open with a blank screen.
To choose the type of Arduino board go to Tools > Board > and select the appropriate one.\
To select the port the Arduino is connected to, look under Serial Port under the Tools menu.
Step 3: Uploading a Sketch
Example sketches can be chosen from Examples under the File menu. To test if everything is working choose Examples > 01.Basics > Blink. This will open the default blink sketch on a new screen. You can now close the old one.
After pressing the Upload button (->) the Arduino’s on-board LED should start to blink on and off at one second intervals.
Step 4: Conslusion
That's it! If the board's build-in LED is blinking the setup is complete!
For more information & tips about the Arduino IDE, see my Blog.
Enjoy =)-~
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
    How do you update the board manager so you can also use esp8266 and esp32?
    Cool idea. I never thought about combining raspberry pi and Arduino in the same system.
