3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Installing Wings Solo
Step 7Mission One Eigth Accomplished
When the wing is on the sawhorses. lift the wingtip and move the wheeled sawhorse towards the center, not quite to the balance point.
Go to the wingtip and push down to lift the wing root. All the weight is on the wheeled sawhorse and now you can push the whole assembly towards the fuselage (fuse).
At this point, you go to the wing root and insert the spar into the center wing in the fuse.
Back to the wing tip and push the spar into the fuse. You will have to lift the rear of the wing to get the proper tilt so the spar doesn't bind in the fuse.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:kkinney
