Introduction: Installing a Custom Bolt Handle
Picture of Installing a Custom Bolt Handle
I recently picked up a new target rifle - a CZ 455 Elite .22LR - and while I like a lot about it, I just can't leave well enough alone.  After a few sessions at the local range, one of the "glaring" shortcomings was the bolt handle.  The stock bolt handle was a little short for my taste and the ball at the end of the handle was kind of slippery and small -so I decided to replace it with a bolt handle that better suits my preferences.
Bolt handles are typically replaced by either cutting off the old handle and welding on a new one, or, chucking up the bolt handle in a lathe with a special jig, turning the bolt knob down, and threading the stub.  The specialized equipment and skills required typically push this modification into the realm of a professional gunsmith, but with a little care and some basic tools, a careful DIYer can do a bolt-handle swap to be proud of for a lot less money and a lot quicker turn-around.
Time and Money:
This entire project from start to finish took me around 2 hours to complete.  Cost was $20 for the bolt handle (eBay) and ~$5 for the thread cutting die - which I picked up at a local auto parts store.  Add in a little more for Loctite and some thread-cutting oil (WD-40 in my case).
As with any project working with metal, sharp things, hot things, pointy things, powered things - be careful and think about what might go wrong and compensate/plan around it.  You're a lot more expensive to fix than most of the things in your shop.  Wear eye and ear protection, and protect your hands.  I use heavy-duty Nitrile gloves (because they let you feel the heat buildup as opposed to leather - yet are still protective).
Step 1: Layout and Planning
Picture of Layout and Planning
The first thing you need to do is make sure that the orientation you plan on installing the new handle isn't going to interfere with anything in either the closed or open position.  Make sure you're going to have enough clearance around the bell of your scope (if your rifle is scoped) and that the handle won't hit the stock or interfere with your hand in the closed position.  In my case, I found that if I just continued the line of the original bolt handle through the ball, that the angle would be about right all the way around.
The basic technique here is the idea that all curves can be broken down into a series of straight lines.  You start by refining the shape down to a square, then turn the square into an octagon, then bevel all the sharp edges again until you have faceted cylinder.  Once you've knocked the corners off of your octagon shape, you can start to refine the cylinder.  The beauty of this technique is that it's pretty easy to judge "flats" rather than curves.  Concentrate on keeping your flat surfaces the same width, and you'll find that a cylinder develops almost on it's own.
First: Put tape on any surface that might get touched by the sander/grinder that you might not want scratched up - 2-3 layers of electrical tape will work.  When working, measure the diameter often - maybe more than you think you need to.  Take your time when refining surfaces - pay special attention to keeping opposite sides parallel to each other - do NOT depend on your eyes as sometimes things look wrong and aren't - and vice versa. Use calipers to check parallel (look for consistent thickness).  You don't need to be super-accurate as the threading process will clean up the cylindrical shape, but the closer you are to truly round, the easier the threading process will be.
In this case, the threads required were 5/16-24 NF threads - so I tried for a final "rough" cylinder at a little below .3125 inches.  My final cylinder had about .003 inches runout, and threaded just fine.
Step 2: Threading
Picture of Threading
The threading procedure is pretty much standard here.  While starting the die can seem a bit intimidating, it will self-correct to an extent - so you don't have to be too paranoid about starting out perfectly perpendicular (but try to be as close as you can).  Take your time and use a cutting oil (WD40 works for me).  For those who have never threaded something, I'd recommend looking for videos on YouTube.  The basic technique is to turn the die a half or quarter turn, then back off to break the chips, add a little oil, make another half or quarter turn, back of to break chips, add a drop of oil, repeat until you've threaded the piece.  I also run the die backward every couple of revolutions to clear everything out.  The most important thing is to not rush the process, and let the tool do the work - don't force it.
Step 3: Assembly
Picture of Assembly
The threaded hole in the bolt handle was a little deeper than my threaded stub, so I cut a piece of brass stock off to make a spacer that I slipped into the hole, and then threaded the handle on to the stub. A little fitting was required to get it to just the right length for this installation. Once it was going together the way I wanted it. I cleaned off the threads of the stub and the internal threads of the bolt handle with solvent, added blue loctite thread-locker, and snugged the new handle into place.
Enjoy your new bolt handle - I can say that on this rifle, it's a huge improvement.
(I also added a couple more bolt handles installed using the same technique - just to show that you're not limited to small rimfire rifles ;)
rafters182 (author)2015-03-23
Nice work! How did you get the consistency in terms of the roundness of the "shaved down" bolt prior to cutting the threads?
jwilliamsen (author)rafters1822015-03-23
Well, it's really just a matter of being kind of careful about the progression of shaping the "stub". I worked to a square first, then to an octagon, then just kept knocking off the sharp edges until the shape was basically round. I measured a LOT to determine where I needed more work, and where I was OK (or a bit too far). The stub is NOT going to be a perfect cylinder, but the die will cut it just fine as long as you're not over your max dimension. The die will true up small inconsistencies. I've done this 4 times now, and it works pretty well. I suppose if you wanted a seamless fit with your bolt handle, you'd have to chuck it up in a lathe, but for my purposes, it's worked out just fine.
joegeek (author)2014-07-21
TY jwilliamsen, awesome work. I've just had a hard shock with the local gunsmith rates here. You also provided me hope that I can do my own work and save literally hundreds (Yes! their rates are bullocks). By the way I really like your Stock, did you make that? It's AWESOME!! :-) best of luck and thank you for your Instructable.
jwilliamsen (author)joegeek2014-07-22
Hi Joe,
Yes, I think this is a fairly easy technique to master - I've installed 4 bolt handles now, and I can't imagine sending this off to have it done given the relative cost (almost zero) and time (a few hours turnaround vs. a week or more). Just *take your time* the first time - remember that you can always take metal off, but adding it back on isn't so easy.
Thanks for the compliment on the stock. I didn't build that - it came "stock" on that rifle. That model is manufactured by Boyd's Stocks (it's their Thumbhole Rimfire model).
Good luck on your install - I think you'll find that it's a easy and quick upgrade for your rifle. It's one of the rare instances where "good, fast, and cheap" can all coexist in a project :)
Growberry (author)2013-09-17
Pretty slick Joe...Nice work!!
jwilliamsen (author)Growberry2014-04-16
Thanks, Gary ;)
gamera_the_brave (author)2014-04-15
Nice work.
I've always thought this would be a tricky job, but you make it look easy. Thanks for the instruction!
It's not that bad, really - just take your time. However you do it, it's still probably quicker than sending the bolt out to have it done. I just threaded a Remington 700 bolt and it took about an hour using the same process - it goes a lot quicker the second time ;) I would stress thoroughly wrapping up the parts of the bolt you're not working on, though - electrical tape has saved me from a few potential scratches.
crestind (author)2013-10-14
Beautiful stock.
pneville (author)2013-09-24
Nice work and rifle
rimar2000 (author)2013-09-17
What a beatiful rifle!
About This Instructable
31,229views
46favorites
License:
Bio: I am a perpetual student, researcher, and hopelessly dedicated skill collector. I hope that you can find something inspiring or useful in the instructables I ... More »
More by jwilliamsen:Make Your Vise PortableSporterize a Military Surplus RifleRestore an Old Vise
Add instructable to:
