3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Installing a Secondary Fuel Filter (diesel)
For my first Instructable, I'll document the steps I took to install a secondary fuel filter in my 1983 Mercedes 240d. Currently I'm running a mixture of WVO and biodiesel. My fear is that I'll be on the road and have to do roadside maintenance because of a clogged filter- now I don't have that problem.
*Please note- if you try this, you do so at you own (and car's) risk.
Step 1Tools and materials
Tools and materials
Tools:
razor blade, or knife
protective gloves
something to catch the fuel that spills
Materials:
Fuel filter- I used a Mann WK 842/3
***3/16" fuel line 4-5 ft***
In line fuel shut-off switch
(x2) 3/16 T-connections
zip ties
Optional:
Hose clamps
-small: enough for all hose connections
-Large: To attach to optional mounting bracket
custom mounting bracket (not discussed in this instructable)
***If you're running WVO or biodiesel, you will want to get synthetic lins such as Viton or A1 grade Marine fuel line.***
10 comments
Dec 22, 2010. 7:59 PMMonkeyboy13 says:
Dude! I have that same car!
Jul 10, 2010. 9:01 AMronorr says:
Very Important. The filter in the parts list is a WK842/2 but the filter in the photograph is a WK842/3. They are rather different. You want a WK842/3 NOT a WK842/2
Sep 14, 2008. 7:38 AMDerin says:
also,diesels feed fuel via gravity
Aug 27, 2008. 3:05 PMalex-sharetskiy says:
That's cool, but wouldn't fuel still flow through the secondary filter even if the switch is "on"? Yay biodeisel, just filter the fuel BEFORE putting it in your tank
Aug 27, 2008. 5:10 PMLinuxH4x0r says:
I think they use the 2nd one and have the original as a backup
Aug 27, 2008. 5:27 PMalex-sharetskiy says:
oh, now i see the creator should change his fuel lines to synthetic ones, Biodiesel (the home-made type) will eat away at your tubes until nothing else is left!
Aug 27, 2008. 1:00 PMgog says:
I'd recommend some hose clamps on those fuel lines so they cant pop off.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:skree
