3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Installing a Slate Backsplash - The Easy Way.
Time to upgrade the house again. As always I try to keep it simple as I can but still make it come out looking high end.
I have extra slate tiles left over from another job, that means I can be creative.
Previously I had built a bar on the outdoor patio and tiled it with these slate tiles. All of the decoration Guru's said "try to bring the outside atmosphere in and this will create a really comfortable homey atmosphere. So I will show you how I installed a slate tile back splash the easy way, actually it was pretty cheap too.
Well I tried it and the wife loves it, some people hate it. So it's either you love it or hate it. Whether you like it or not is really not the point, it is how we did it that matters. Hopefully you will learn some new ideas or can provide some "positive" suggestions. Read on my friends and see all of th pictures on the last page.
If you have any suggestions on how this could have been made better, easier, safer etc. please post them.
Please let me know if you like how it came out or if you don't like it. Also please tell me why why you do or don't like it. You are welcome to rate it on a scale of 1-10 with 1 being "I hate it" or 10 "I absolutely love it."
Thank you for taking the time to read this "ible" and providing feedback.
Have a great day!
P.S. if you notice spelling or grammar errors please let me know so I may fix them :)
Step 1Consumables List
Consumables List
1. (2) cases of 4 inch square engaged slate tiles from Home Depot. about $11 each x 2 (cases) = $22.00 (about 50 tiles per case)
2. (2) tubes of adhesive Loctite Power Grab
3. Caulking gun
4. (1) bag of Type S High Strength Mortar/Stucco Mix Gray (we had left overs from a previous job) $3.50 - $4.50 per 80lb bag Sakrete
5. (1) Roll blue painters tape] Tape
6. (1) Tile Sealant
7. Tile spaces (1/4 inch)
8. Rubber/latex gloves
64 comments
1-40 of 64next »
Dec 29, 2011. 8:28 AMcivilman says:
Most installs tell you to use a silicone caulk on the outside edges of the project, is this required or a option? Just getting ready to start mine and don't want to screw it up.
Dec 19, 2011. 11:36 PMpaintchick says:
Nice project. A good, neat job.
$50 will get you a nice little wet saw at Home Depot. As a tile setter, I've used nippers, dry cutters, angle grinders, and ginormous wet saws. My little $50 saw has seen me through many tile jobs, is easy to set up, clean and transport, and cuts smaller tiles easily. I will never use an angle grinder again on a tile. And after a couple of years of use, if my little saw goes to the big tool box in the sky, I'll consider it good money spent for making tile cuts simple and safe. When I am setting large tile, though, nothing beats the 24" bed of the big saw.
Also, I use a yellow 'grease' pencil to mark dark tile like slate. When marking many tiles for cuts, such as underneath an upper cabinet, I'll mark the back of the tile 1 or A then pencil on the wall the same number where the tile goes. The next tile is 2 or B and so on. That way you can production line all the marking and then all of the cutting.
Lastly, most grout packaging will indicate whether natural stone tile such as slate or marble needs to be sealed before grouting.
Again, good work. The care you used shows.
Dec 19, 2011. 10:17 PMjbrecken says:
I had a slate floor installed, and the installer messed up and did a sloppy job cleaning off the grout before sealing, and muddy streaks from where he wiped were sealed onto the tiles, because it was an impregnating silicone sealant that could not be removed with any solvent. (We complained loudly and eventually they came back and ripped up the floor and put in a new one.) But in the process of educating myself after the fact, I read a number of sources that recommended sealing the tiles before grouting. They said that not only does it avoid the problem I had where grout gets under the sealant, but it makes cleaning the grout off the tiles easier if they are sealed. One installer I talked to said that he sometimes even seals the tiles before laying them.
Dec 19, 2011. 12:47 PMScuba3537 says:
If you really want the kitchen to look nice, put some knobs on those cabinets! Otherwise, great job.
Jun 30, 2011. 7:38 AMouchthathurt says:
cant seem to find that nifty angle grinder kit ... I looked on the harbor freight site, but they don't seem to sell it any more any idea?
Dec 19, 2011. 6:55 AMswitch998 says:
I guess you got it already, but I just got one at home depot for $.01. It's a clearance item, so YMMV, but if you can find it get a bunch ;)
Apr 24, 2010. 1:43 PMfrydaddy says:
What a nice instructable. Yet once again, the common man can have great outcomes in "do it yourself" projects with the help of great instructions on a great site. well done.
Mar 21, 2010. 10:42 PMfiducianullus says:
I think you mean "un-gauged" tile. Slate can't get married.
Feb 28, 2010. 11:17 AMflymom says:
Love your instrucatible!  My backsplash is currently contractor off white, 12 years old.  If water were a big problem I am sure I would see the results of such. In other words, the backerboard isn't really needed. I think you should definitely finish the rest the same way!  Why not try to chip out the shape and size of your outlets some of the tiles?  i haven't done this myself, but it may be fun experiment.
Feb 28, 2010. 11:05 AMflymom says:
I use an icing bag, a plastic cone shaped bag for icing cakes, to grout smaller tile jobs. Really easy and much more precise. They can sometimes tear, so have extras. I also find that cheese cloth is the best I have used to clean the excess grout when finished. It's texture helps to remove more of the sand, rather than just move it around.
Oct 14, 2009. 10:44 PMLMichel says:
It is always recommended that, when purchasing tiles, you buy too manyrather than too little. This way, should any tiles become damaged or ifyou require more coverage, you will have the same style of slatebacksplash tiles. In addition, you will find that polished slate is mucheasy to clean.
Here is another link that might be useful: Create a Unique and Fresh Kitchen with a Slate Backsplash
Sep 6, 2009. 5:12 PMdevsharon says:
I don't understand how you only spent $22 on tiles.... the same ones on the home depot website are about $8 per square foot (which according to them is only 1 case).
Sep 6, 2009. 8:11 PMdevsharon says:
definitely a lucky find. Well, it looks beautiful. Congratulations.
Apr 20, 2009. 12:30 PMshaunaz says:
The backsplash looks really nice....one question about the slate though... Normally slate tiles flake (on the surface), how did you take care of that? Does sealant help with that. I do not want the flakes from the slate backsplash falling on my cooktop. And can we wipe them with wet cloth to clean them regularly?
Jun 25, 2009. 1:42 AMgunnerjake81 says:
I appreciate the idea of this easy job.. but did you really glue it? can't think of a worse way to do it. well there is gum.. as a pro in the tile industry i cringed when I read "locktite power grab" it does look awesome though
Feb 26, 2009. 1:39 PMthorhaglund says:
You misspelled put (you put pit, and you asked!)
Feb 16, 2009. 10:31 AMPompom says:
This backsplash is so beautiful! I have a bunch of leftover slate from the kitchen floor of our last house, and I was wondering if I could salvage it for our current kitchen revamp? None of the pieces are even though, from being pried off of the floor and then damaged by age being kept outside, so I had used some of them to create painted artworks. Maybe they could be cut much smaller for a backsplash...?
Sep 6, 2008. 9:26 PMlaniergardener says:
Thank you very much! Ive been the "contractor' on my kitchen to save $, its a total gut job. I have however been without a kitchen for a month and counting...Im about ready for the back splash.. You had some great info and im using same tile as yours if not pretty close. i got a quote from 500 to 300. I was thinking of doing it myself but I think 300 I will let the pro do it. Still, I appreciate what you have done & thank you for the info. . I now know to make sure the guy uses backer board and flat sealer, i dont care for the shiny, and to ask him about thin set. Thanks much, all this was very useful. I do have question re the outlet covers; the tile is thicker than the outlets with covers. Will the tile guy be able to make all of it even/flat so to speak, does this make sense? Thanks again.
Dec 26, 2008. 7:45 AMkenn123 says:
if your contractor is competent enough, they may even be able to use a tile as a face plate for switches and outlets, in which case no need to worry on flatness
Dec 23, 2008. 10:12 AMDIYDragon says:
Awesome! I love these types of splashes - Looks very nice with your cupboards too. I definately want to do this at some point. Favorited for later. : )
Nov 17, 2008. 11:44 AMEnglishem says:
Thank you so much for posting this. I got new granite countertops and wanted to do a backsplash myself. After researching via various books I was getting discouraged and thinking it would be too much for me, but your guide makes me think I can do it. Love the embedded comments in the photos!
Nov 7, 2008. 6:44 AMkaylie08 says:
Hi, my husband and I are thinking of making some improvements in our kitchen and I was suggesting that we copy the design I saw at this site http://www.bathroomandkitchenguide.com/Kitchen-Tiles-Splashbacks/10-modern-splashback-ideas.html. I really like the shiny red back splash but I can't get him to agree with me. Now after seeing this, I see why he likes to have slate back splash instead.
Nov 6, 2008. 8:24 PMtoklatkate says:
Beautiful girl... ah, beautiful tile job also! I like the "homey" look it gives, but also like the bit of a shine it has. I like it much better than "traditional" kitchen tiles. I only skimmed your directions, but from what I saw, I'd say its a great "ible." I give it a 10. toklatkate
May 16, 2008. 6:15 AMsmith2martin says:
Very nice. I've got a tile job coming up myself, and was looking for an easier way to go about it. I'm with your wife, I definitely like the shiny look (and it probably wipes off better as well). Thanks!
May 16, 2008. 6:04 AMsmith2martin says:
BEWARE the mighty angle grinder! In my opinion, this is one of the most dangerous hand tools, right up there with the chainsaw. The speed with which the grinder turns is extremely easy to take for granted. Any amount of kickback can easily result in loss of hand / arm / nose. ALWAYS use two hands, be sure you're in a braced position, and never become lazy or nonchalant while grinding. Sorry if I seem overly passionate, but I had a buddy that recently almost lost his hand via a sanding disc on his grinder (and it was his fretting hand to boot). Grind safely!
May 16, 2008. 5:52 AMsmith2martin says:
"Sealnt" above should be "Sealant", FYI. Nice job so far... still reading.
Mar 21, 2008. 2:31 PMgwrober says:
Excellent job! But thanks, cuz now I have work to do in the kitchen since you showed us that it's sooo easy. I have a wife to please too. ;)
Feb 7, 2008. 10:11 AMbikr says:
Dude, that looks great! One question.. Any reason you didn't take out the backsplash below the tiles and have that wall's splash be continuous? Not a negative persay, just think it'd have been my preference and wanted to know what your thoughts were on it.. I'm getting ready to do this in my new built house, builder wanted way too much for it, but i'm going to use tumble stone tiles at a diagnal.. :) Either way.. great work man!
Oct 2, 2007. 11:53 AMjerwhite says:
I like the instructable and don't ever comment on these. But having installed tile myself the traditional way, I would have both added a couple of comments(disclaimer rather). This will work but in the event you are installing tile in a wet environment, you should use backer board and also use thinset. The backer board is water resistant and helps the thinset bond better. In any case this installation is a unique approach and probably easier in a dry environment. My last comment is that I would have removed the wall outlets before installing the tile
Sep 5, 2007. 11:24 PMValster says:
WOW! Nice job! I especially like the running bond pattern you used. I suggest you change the outlets. The stark white takes away from the beauty of the tile. Maybe grey to complement the tile or black to match the appliances? Also, definitely do the rest. Honey may be happy with what she has but she'll be thrilled if it all matched.
1-40 of 64next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
46
Author:Mr. Rig It
I like to build, create, and invent new things to use in life. Sometimes I like to share them with others, that's why I joined Instructables. :-)
