3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Installing a Slate Backsplash - The Easy Way.
Step 11Installing the Grout
Time to install the grout.
You will need your eye glasses and some rubber gloves (if you choose). SAFETY NOTE The grout mix is a little caustic and can also make your skin raw from rubbing sand particles. It is a wet version of sandpaper.
We used stucco mortar mix, because that is what we used outside. We also thought it gave a more old world look.
When mixing follow the instructions on the bag, for the type of application that you will be using it for.
Our mixture ended up a little thicker than ketchup.
Typically you use a trowel to apply grout. However, I have found this can get really messy. We used our hands and just pressed it into the gaps with our fingers. It was very easy to work with. It was still messy, grout always is, it was just less messy and less work to apply it by hand.
INFO NOTE We also only mixed a small amount at a time. Since our mixture was dryer than normal, it started to dry out in the bucket quicker than normal. So make it as you go. No need to mix up an entire 80lb bag.
Apply your grout. Let dry, Then with a wet rag or sponge wipe the tiles clean. you may have to do this 2-3 times or more. That's why I didn't use a trowel, trowels can really make a mess of small jobs.
1 comment
Feb 28, 2010. 11:05 AMflymom says:
I use an icing bag, a plastic cone shaped bag for icing cakes, to grout smaller tile jobs. Really easy and much more precise. They can sometimes tear, so have extras. I also find that cheese cloth is the best I have used to clean the excess grout when finished. It's texture helps to remove more of the sand, rather than just move it around.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
46
Author:Mr. Rig It
I like to build, create, and invent new things to use in life. Sometimes I like to share them with others, that's why I joined Instructables. :-)
