Installing a Toilet; Home Improvement
 by PaleoPunk
Featured
Step 3: The Tank
On many modern toilets the inner workings of the tanks are pre-installed, so all you have to do is set the tank on the bowl and attach the hose for water. The water hose is attached to a a valve that will be off. It should be fairly obvious where to attach the hose on the back of the toilet (it will just screw on). Turn the valve on.
Congratulations, your toilet should work now.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
