3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Installing a USB Keyboard into an OLPC XO Laptop, Phase I
Step 2Shucking the Keyboard
It's time to take the case off of the ASK-3100 Series Ultra Mini Keyboard. There are eight screws on the bottom of the keyboard, but three of them are hiding from your screwdriver. Two of these cowardly screws are below the rubber feet to the front of the keyboard; peel the feet off with your thumbnail or a pointy stick. The other one is behind a sticker marked "DO NOT REMOVE." You know what to do.
Once you have the shell off, you need to disconnect the ribbon cable between the keyboard and its controller card. But wait! Unless you can design original origami figures in your head, you should take a pen and mark both the cable and the connector with an asymmetrical symbol, like the letter "F," right where they meet up. That will help you later when you have to put them back together the same way they started out. The small circuit board with the caps lock, num lock, and scroll lock LEDs on it is the controller card. The ribbon cable is about to have a bad day, so pull it gently straight back from the connector.
1 comment
May 15, 2008. 11:24 PMnish2575 says:
i love the tone. makes me crack up
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:labelreader
