Step 7Make a Big Scary Hole
This time it's going to be a keyboard-controller-sized hole in the steel plate the keyboard's sitting on. The hole will offset some of the thickness of the controller so the XO's case will actually close again. Yay.
Align the card more or less with the ribbon cable, trace around it, then cut along the dotted line. Add an extra opening for the ribbon cable so it doesn't get crunched up against the card. I used four Dremel wheels cutting mine. Hopefully you can do better. Make sure you de-burr the edges, especially around the extra space you gave the cable, so any contact it has with the steel is nice and smooth. If you want to be extra safe, cap that steel with a piece of cello tape.
Dremel away the "ribs" running along the inside of the case opposite the controller card, so that the card will have a little more room on that side, too.
Run the USB cable up and out of the case, following the trackpad controller cable, and stick everything back into place. I used plenty of cello tape. Isn't it lovely? Luckily nobody will ever see this again.
Your job is done! Call in your closing surgeon to reassemble the XO. Do remind your colleague that the stitches will have to hold extra tight, because the patient has new and bigger guts. I'd recommend feeding the USB cable around the hinge and leaving the hinge cover off for now.
5
comments
Add Comment
labelreader (author)
says:
Add Comment
