3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Installing a ball valve on a Coleman cooler
In this instructable, I will show how I installed a ball valve on a Coleman cooler.
A cooler with a valve installed is the first step in building various equipment for homebrewing beer. Once the valve is on, this cooler can be made into a mash tun or a wort chiller. This instructable is meant to be the first step in my following instructables on how to build these.
This will allow you to drain liquids from the cooler at a controlled rate and will be simple enough to disassemble and clean.
Step 1Rule # 1 aka "The Golden Rule"
Rule # 1 on making equipment to make some tasty homebrew is to have a tasty homebrew!
Please note: Have all of your materials on hand ahead of time. You don't need to be driving to the hardware store after following the golden rule.
31 comments
Sep 20, 2010. 4:20 PMfurby says:
this (if big enough to fit your fermenter) could be used as a "Light Lock" and a crash chiller. i have 2 15L fermenters and could probably fit both one of these.
Apr 9, 2010. 8:18 AMtinman50 says:
Quick for clarification question. The rubber washer goes on the inside of the tank, correct?
Oct 8, 2009. 8:11 AM3frog says:
Hey
Great idea, even if you use it to drain your cooler while camping!  I would recommend using braided hose. This is a much stronger hose that will not kink, bend or get damaged if anything is put on top of it by accident.  It is a little more expensive, however for 2 to 3 feet the difference might be a couple bucks!
Oct 12, 2009. 6:07 PMonlinenow says:
Do you mind if I ask what part of the country you are in?
Oct 8, 2009. 2:36 PM3frog says:
You lucky guy!
Oct 13, 2009. 7:38 AMtashiandmo says:
Nice 'ible.  I second the suggestion to replace the washer on the one you're going to use for the mash/lauter tun.  The highly acidic wort will corrode that one after just a use or two (don't ask me how I know that).  I used hard plastic because it was what I had on hand at the time, and it was cheaper than buying a stainless washer.  The washer you used should be okay for the wort chiller and the hot water tank though, just replace them if they start to show signs of corrosion.
Oct 11, 2009. 7:41 PMhusker says:
 Sticks out way too far
Oct 9, 2009. 7:22 AMt.rohner says:
Nice instructable,
i was thinking about one of these 10 years ago. (When i started all grain)
But in the end, i decided that i want to be able to do step mashes, without the need of a decoction. So i use a 50l keg with a burner and insulation.(in the meantime, we have a new insulation installed)
I got all three kegs for 150$, and built the tower with the help of a pro-welder. He also enlarged the boiler to hold around 75l  (20gal).
We brewed around 400 batches with this setup.
In the second pic, you can see my brewbuddy willy stomping Sauerkraut.(Upcoming instructable) Left of the blue barrel, there are our 3 new 100l (26gal) stainless containers. The one in front with the sticker was used to raise money during our 10 year anniversary. We will soon step up our production with them...(I was very lucky, i got them for free)
Oct 1, 2009. 6:55 PMSpeidumb says:
Do you think this would work for the fermenter? Drill a hole in the lid, add an airlock, then make sure something heavy is on it so no air gets in. This would make bottling a ton easier if I didn't have to siphon and could just use the ball valve straight into the bottle.
Oct 8, 2009. 3:58 PMairecrist says:
speaking of airlock i'm still waiting on that instructible for building a moonbase :P
Oct 8, 2009. 10:08 AMyopauly says:
How about a brass quick disconnect to get it out of the way when not in use. How about attaching the hose to the cooler and putting the valve at the end of the hose? Just some friendly ideas for you to ponder. 8)
Oct 8, 2009. 9:20 AMThe Lightning Stalker says:
I recommend using a stainless steel washer on the inside of the cooler since it will be in contact with beer, which can be very corrosive.  The washer on the outside will get cold and "sweat", so stainless is good here as well.
Oct 8, 2009. 9:28 AMmorgano says:
Are you planning to use the internal coupling to hook up a hose braid, and then batch sparge with this setup?  Or would a manifold thread into the coupling?  Just curious.  You might want to either expand this instructible or link to another one to show how to complete the mash tun.  Nice job!
Oct 8, 2009. 9:36 AMThe Lightning Stalker says:
They make special nuts that will thread onto the pipe thread.  You can use that instead of the coupling.  You could also drill the hole out bigger and use what is called a 'tank adapter' or 'tank fitting'.  You could even use an old water heater instead of a cooler since they are insulated.
Oct 8, 2009. 6:10 AMMig Welder says:
cool
Oct 5, 2009. 9:43 PMmalopez4785 says:
How do you sanitize one of these bad boys? What stage do you use this for, priming?
Oct 5, 2009. 1:30 PMKoosie says:
Rather than putting cans and ice in there, empty the cans into the ice. Can u say: Ultimate Chug!"
Oct 5, 2009. 9:00 AMSoulproperty says:
This is how many people, myself included, made their mash/lauter tuns. All you need is a manifold attached to the nipple on the inside of the cooler. works great. However, this would make a terrible fermentation vessel. Use a carboy or a bucked. The plastic in the cooler is soft, can scratch easily and will end up harboring bacteria.
Oct 4, 2009. 10:00 AMdrewSaysGoVeg says:
Neat. Thanks for the details. Might do this to use for my gravity-feed shower
Oct 4, 2009. 6:35 AM~Sasquatch~ says:
Dunno about using this as a fermenter - plastic absorbs impurities and odours that might affect the must/mash. Just my $0.02;)
Oct 2, 2009. 7:41 PMuknative says:
You should always clean brass by soaking in vinegar for at least 30 mins, to clean off any chemicals from the production process, otherwise this is an awesome idea. Another which I wish I had thought of.
Oct 1, 2009. 12:41 AMTape-structable says:
Wow! It comes out so smoothly. Nice!
Sep 24, 2009. 9:20 AMahava488 says:
That's a pretty awesome way to start brewing your own beer. And I'm sure it's cheaper then buying a whole kit for brewing. :) Hopefully I can try it out myself one day.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
129
Author:iPodGuy
Just your average handyman.
