Remember, if you don't know what you are doing or you are not comfortable doing this don't do it!!! Because i am not liable for anything you do. Avoid tuching anything you don't need to tuch, everything in the computer is very Sensitive to hand oils.
Remove these ads by
Signing UpStep 1Getting started
screwdriver (not magnetic)
add-on cards
computer
First you will need to turn off your comuter. After you have done that you need to unplug every cord connected to the computer.
I can understand unplugging the power chord, but there should be a switch on the power supply to turn off the power to everything. After turning this off, the computer should be un-powered and safe to work with. The advantage to leaving the power chord plugged in (and turning off the master power switch) is that the computer will remain grounded, helping to prevent any static electricity buildup. This shouldn't be a problem, but it does provide a little piece of mind. Tough if you plan on doing a lot of work, or if the power supply doesn't have a switch on it (not the power switch on the computer, a separate switch on the back of the computer, beside where the power chord plugs in) then yes, please unplug the computer.
Unplugging everything else seems like it would be more of a hassle then anything. I could be wrong mind you, but it makes sense.
And grounding yourself by touching the mettle case is a must before you do anything else, including taking the card out of it's package.
