Introduction: Instamorph
Picture of Instamorph
InstaMorph: Mold-able Plastic
Step 1: Package
Picture of  Package
First, you'll need to have the InstaMorph package, containing the beads that will become the mold-able plastic.
Step 2: Boiling
Picture of  Boiling
Dump the whole package into boiling water (specific instructions on package) and boil until all beads turn clear. Take out of water and place on a plastic plate or board, wait a minute to have it cool down.
Step 3: Playing Around
Picture of  Playing Around
After cooled for a little, knead the plastic, then start messing around. Just building small knick-knacks helps you get used to how it works, feels, etc.
Step 4: Sculpting
Picture of  Sculpting
Begin making a usual tool, or a fun toy to use at home. I suggest having an idea in mind before starting, that way the plastic doesn't harden before you're done.
Step 5: Reboiling
Picture of  Reboiling
If the plastic begins to harden before done sculpting, just put back in boiling water. You can either dunk the whole chunk of InstaMorph, or just certain parts as shown in the second picture.
Step 6: Final Touches
Picture of Final Touches
After you've finished making your desired product, I suggest dipping it quickly in the water so that you can smooth it and make the creases less noticeable. This way you can also make simple adjustment if needed, such as angle adjustment, flattening fixes, or making something thicker or thinner.
Step 7: Finished Product
Picture of Finished Product
After finished making adjustments and making it as desired, all you have to do is wait for it to dry completely. My finished product is a phone stand, but after finishing this project I'd do better finishing touches to make it look better.
Step 8: Left-Overs
Picture of Left-Overs
Since my phone stand didn't take up much InstaMorph at all, I reboiled the rest, making it so the plastic was mold-able yet again. This process only takes seconds. It will take longer if in a ball because the water won't heat up the middle of the ball, so try to have the plastic be as flat as you can before reboiling.
Step 9: Wiring
Picture of Wiring
After seeing a slug my teacher made that lights up, I wanted to make one because it looked super cool and used up the rest of my InstaMorph. While my InstaMorph was reboiling (took forever because it was in a ball) I wired two LEDs, a battery adapter, and a resistor with the help of Mr. Hampton. This piece will make the eyes appear to be glowing red.
Step 10: Wraping
Picture of Wraping
After the wire is complete, make the InstaMorph into an oblong shape (shown in picture) and put the wire on top of the warm plastic. Then, wrap the plastic on the side around the wire. Form an almost circular shape, but not quite. Make the LEDs into the eyes, by forming little nub like things on the top of the slug with the LEDs in them (shown in next step).
*This step has to be done fairly quickly to prevent it from hardening.
Step 11: Finished Product:Slug
Picture of Finished Product:Slug
This is roughly what the slug should look like. I was rushed when making this, so it didn't turn out the best. Although, it does look extremely cool in the dark, and is easy to make. Overall this project was super fun and probably my favorite. I'd definitely look in to getting some more of this to just play around with.
krummrey (author)2015-05-10
This is another playful variation
tomatoskins (author)2015-04-22
So much fun!
JavaProgrammer (author)2015-04-22
so cool! there is another plastic just like this called plastimake and its video said to drop in cold water when finished(to cool).
About This Instructable
1,197views
15favorites
License:
More by Nicki-Flash:Instamorph
Add instructable to:
