An ancient weapon like a metal sandburr. It's a nail with multiple points that has at least one point upward no matter how it lands. They are also called "star nails". This is the quickest way to make them.
Warning:
Some people consider caltrops a political weapon in this era of wars for oil for vehicle fuel.
If you are such a person you should pursue your ends by peaceful means instead.
Remember Noam Chomsky's advice:
"If you fear the government the proper response is to get more involved in government, rather than less so, because the Government really is the institution that represents you."
Watch the movie "Weather Underground" to find out what some famous political vandals wish they'd done instead.
I think it was Bill Clinton who said, "It's best to conclude that bad policy is caused by ignorance, not malice."
Safety Warnings:
Flying sharp metal will hit you in the eye.
If someone steps on one of these they'll get hurt.
Excellent photos by theinfonaut
Step 1: Nicaraguan Caltrop
Caltrops in the Gallery of Heroes and Martyrs in the town of Masaya, Nicaragua.
These look like barbed wire barbs cut off and welded together, but they're much larger than any barbed wire I've seen. These were used in the revolution against Somoza in the late 70's. Nicaraguans threw them onto roads in front of troop truck convoys to delay them with flat tires.
Somoza was a ( yawn, yet another ) U.S. supported brutal dictator.
By the way, a recent issue of Time magazine reported that Nicaragua now has the lowest risk of terrorism in the hemisphere.
Step 2: Chicken Wire Ain't Chicken No More
Cut off some cross-shaped chunks from the chicken wire using a bolt cutter.
Then cut the ends off again at an angle to make them sharp. Watch out for flying bits of sharp metal hitting you in the eye.
Step 3: A Tripod and a Spike
Bend the sharp wires as shown. You're done!
Be super careful with these nasty things and don't leave them lying around.
These are only to carry in your pouch at the renaissance festival as part of your costume.
1-40 of 65Next »
generalmesh says: Mar 29, 2012. 7:51 PM
Hebei general metal netting Co.,ltd mainly produce and export brass wire mesh ,Phosphor Bronze Wire Mesh and red copper wire mesh ,etc for 10 years.
Uses: screening a variety of particles, powder, porcelain clay, glass, porcelain, printing, filtering liquid and gas,Mining, metallurgy, construction, medicine and other industries of the screening.
http://www.generalmesh.com
generalmesh says: Feb 23, 2012. 8:55 AM
http://www.weldmeshfence.com
China Manufacture of wire mesh fence,weld mesh fence,fencing wire,fence panel,panel fencing- Hengshui werson wire mesh fence Co.,Ltd
generalmesh says: Feb 23, 2012. 8:54 AM
The world very famouse filter mesh ,wire cloth ,mesh screen ,shielding mesh ,paper making mesh manufacture and exporter .
radiorental says: Aug 14, 2006. 6:34 AM
"Warning: Some people consider caltrops a political weapon in this era of wars for oil for vehicle fuel. If you are such a person you should pursue your ends by peaceful means instead." It would seem to me that anyone using these for such a purpose would also want to weigh up this 1) Will cause the car owner to go and purchase a new tyre - more consumption. Although I guess the tyre could be easily repaired 2)If more than one tyre is pucntured it would mandate a pickup truck call-out, more gas consumption 3)Very unlikely to change the car owners mind about the use of their car. A more effective method are those stickers "did you know your SUV is causing global warming"
Lokisgodhi in reply to radiorentalJan 6, 2012. 9:45 PM
You're assuming that the person will care about your opinion beyond the fact that they are inconvenienced by having to remove the sticker from their vehicle. That's probably unlikely to be the case.
Caltrops are minimally destructive device and will cost significantly longer in money and time to repair or replace the tire. They're non lethal assuming one isn't moving at a high rate of speed when you hit it.
The last, more extreme option would be to devise a catastrophic or lethal device, like a cable strung across a thoroughfare or and IED.
sonaps in reply to radiorentalDec 18, 2007. 4:24 PM
this guy should really learn how to spell the word "tire" in the correct fashion, it isnt hard, just think (referring to radiorental)
Weissensteinburg in reply to sonapsJan 1, 2008. 10:51 AM
"Tyre" is actually the correct spelling in British English. It's just like "colour".
jswilson64 in reply to radiorentalSep 21, 2006. 10:13 AM
Doesn't the production of bumper stickers cause global warming? ;-) Better to just leave a note. I particularly like: "Santa knows you're causing global warming."
Lokisgodhi in reply to jswilson64Mar 24, 2008. 11:13 PM
Using a schrader valve core remover and taking the core out of all four of the valve stems is rather effective too.
btackett1 says: Nov 3, 2011. 12:12 PM
these can also be used as a project for school if your school has you do a project that requires you to research on something from ancient times
BenEatsNails says: Feb 23, 2010. 12:56 PM
 if you can bent it with a set of pliers then a car or even a shoe is gonna bend it.
but this work in bigger scale
cooy in reply to BenEatsNailsMar 4, 2010. 5:10 PM
the caltrops that he describes will not work. however if done on a large scale like you suggest.  I would know this as these caltrops just got me expelled from school by getting back at another student.
btackett1 in reply to cooyNov 3, 2011. 12:10 PM
lol wow u failed
weldmeshfence says: Mar 25, 2011. 6:10 PM
AXHEJAZ says: Feb 7, 2011. 12:29 PM
simply awesome! thanks man, i'm going to try to get thicker wires though to make the caltrop stronger!
ninja patrick says: Apr 23, 2010. 10:00 AM
wow it is assum
you are briliand
it is so easy and cheap
but is it strong enough?
don't it breack whan a human stand on it?
tsukiyomaru0 says: Apr 19, 2010. 10:12 PM
Ah, I knew I'd see something that thought like me... This might work great if you're running from someone that you believe that may want to harm you in any way. Team it up with CD kunai or Shuriken for MASSIVE DAMAGE!
Jesus10555 says: Dec 15, 2006. 6:21 PM
lol, if they are only for pocketing at the renaissance festival, why do you have pictures of them situated under a tire, lmao
mazeka.14 in reply to Jesus10555Dec 7, 2008. 9:45 AM
what does imao mean?
goeon in reply to mazeka.14Jan 18, 2009. 5:08 PM
laugh my @$$ off
seabee890 in reply to goeonOct 31, 2009. 2:08 PM
??? What does @$$ mean ??
teslafan100 in reply to seabee890Dec 29, 2009. 6:44 PM
@$$ means butt. lol
seabee890 in reply to seabee890Oct 31, 2009. 2:08 PM
just kidding
loppy96 in reply to goeonAug 4, 2009. 1:01 AM
thanx
mazeka.14 in reply to goeonJan 19, 2009. 2:41 PM
awesome!!!!!!!!!!!!
Colonel88 says: Oct 27, 2009. 12:47 PM
Put these in your pocket so when someone tries to pickpoket them they go OWCH.
backyardmunitionist says: Oct 1, 2009. 7:48 PM
rofus says: Apr 26, 2009. 9:50 AM
these are so simple to make. i cant believe i didnt think of this bafore. ty
pudicobar says: Dec 8, 2008. 7:04 AM
I guess you could make a potato cannon and fill this stuff to be shot from behind your car... ;-) . BTW, I think those fence staples welded would do more damage,
shadow12952 says: Oct 30, 2008. 5:08 PM
good idea
Thelonelysandwitch says: Oct 17, 2008. 6:50 PM
these arent near strong enough to pop a tire, these can berely pop a bike tire, use very strong nails welded or twisted together.
Lokisgodhi says: Oct 29, 2007. 1:31 AM
That's NOT chicken wire. Chicken Wire is braided wire in hexagons.
The material shown is Galvanized Fencing Mesh.
http://www.mesh-fence.com/wire-mesh/welded-wire-mesh.htm
NFI in reply to LokisgodhiSep 16, 2008. 8:57 AM
Huge "bump", but you're right - that's not chicken wire. I don't know what these people are talking about.
jeffconnelly in reply to LokisgodhiMar 14, 2008. 9:06 AM
I'm sure you know what you're talking about, but I'd say that most people would call it chicken wire.
tigerboy in reply to jeffconnellyMay 15, 2008. 1:32 PM
exacty
smokehill in reply to jeffconnellyMar 23, 2008. 1:07 AM
At the risk of sounding like a smart-ass, I feel compelled to mention that no one who had ever kept chickens or knew anything about them would call that chicken wire, since it obviously wouldn't work to keep chickens in. Most people who buy or use it call it galvanized fencing, "welded wire," or "hog wire" -- though real hogwire is wrapped, not welded. Most 2x4 wire is used for staking tomato or bean plants, or for keeping idle chompers out of your garden. Baby chicks, or even small banty chickens, would walk right thru this 2x4-inch mesh. As Lokisgodhi points out, you need to ask for the right thing in order to get what you want. The wrapping on these should be done tightly, since more than likely the cheap spotwelds on 2x4 welded wire will probably break somewhere during this process. Homemade caltrops are often made by epoxying four shingle nails together at their heads, as some vets may recall. The OSS made caltrops for use by resistance forces, and issued instructions for making your own from wire or nails as a field expedient to disrupt Nazi transportation.
JonFG in reply to smokehillJan 6, 2012. 8:31 AM
I have been dealing with wire mesh for a long time.. If you really want to see the variations on wire mesh fencing, inclucing chicken wire and welded wire, galvanized and all the size and mesh variations.. you can check http://www.academyfence.com/welded-wire-mesh-fence or http://www.weldedwirefence.com
Lokisgodhi in reply to jeffconnellyMar 14, 2008. 10:51 AM
If you're ordering chicken wire with the expectation of making these, then you're going to be disappointed with what arrives.
Notbob in reply to jeffconnellyMar 14, 2008. 9:20 AM
I would have to agree jeffconnelly, I would have called that chicken wire too.
Meispantyshot in reply to NotbobMar 14, 2008. 11:29 AM
1-40 of 65Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
