Instant Thumb Piano: How to make a set screw lamellaphone
This is a method to quickly and easily make a musical instrument capable of melodic percussion and noise experimentation.
The thumb piano, known as a kalimba or mbira and by many other names, is a lamellaphone that uses plucked prongs called tongues, keys or tines to generate acoustic vibrations. The length of the tine determines the pitch.
Generally, the thumb piano uses some kind of mechanism to create a great deal of pressure to anchor the tines across 2 bridges which allows the free lengths of the tines room to vibrate. The tines are usually of the same material and gauge (thickness) to ensure consistency so the pressure is distributed equally holding everything in place and in tune.
The method shown here is simplified and wonderfully versatile. It allows the use of more fragile, delicate, and unusual materials for the body of the instrument, and it provides a way to use oddly shaped tines of different materials at the same time while permitting the tines to be swapped out and tuned with ease.
There are interesting possibilities here: a simple armature or jig that becomes a tool with which to investigate the sound that different materials make - how they vibrate, how they resonate and how different combinations of factors can change the sound quality.
Experiment and explore and find configurations that work for you.
More photos:
Flickr set
Video link in Step 6.
Step 1The Grounding Bar
The Grounding Bar
The grounding bar is an item used by electricians to ground house circuit wires. It comes in a variety of lengths and can be found in the electrical section of most local hardware stores or builder/contractor supply centers.
The bar shown is about 4 1/2 inches long and 1/2 inch in width.
The 3 empty slots are drilled all the way through, this is where fasteners can be used to attach the bar to something.
45 comments
1-40 of 45next »
Jan 23, 2012. 12:31 PMmarktreefrog says:
by gluing down the grounding bar and finding more screws I was able to use all of the ports. So no gaps. I used JB weld for this.
Jan 23, 2012. 10:43 PMmarktreefrog says:
I like that idea. I will have to try that. Another fun addition is a piezo pickup and jack. this picture shows every thing tape in place temporarily before glue and soldering for a more permanent fix.
Oct 8, 2007. 6:58 PMblacksmith_tb says:
What's the source of the 'blue spring steel tines'? They look like a nice, uniform choice.
Jul 21, 2009. 2:34 AMmmbutler says:
A typical metal-tine grass rake will give you a lifetime supply of one width of blued spring steel tines, though they'll typically be overpainted some other color . :)
Nov 19, 2011. 3:29 PMDublA says:
Of course!! A rake! You can't imagine the time I spent wandering around Home Depot aimlessly trying to find something approaching spring steel.
Oct 17, 2011. 10:47 AMtankdo says:
Well, first, good instructable! i have the same problem trying to find the "gorunding bar" because im in latin america and i didn´t knew the spanish name, that piece is also known as Terminal Bar or link bar conector, in this case, a 15 way Terminal Bar, i hope this help!
Para los amigos hispanohablantes: la pieza se consigue como Bloque De Terminal de metal o latón o Barra Terminal de latón, o Bloques de Tierra de 8 vías (o de las vías que sea dependiendo del nùmero de hoyos) está catalogado en la electrónica como accesorios de puesta a tierra, por eso en inglés lo llaman Grounding Bar.
Espero que les haya servido la informaciòn, realmente es un instrumento hermoso y vale la pena hacerlo!
Oct 19, 2010. 6:21 PMrhysc says:
Did anyone from Australia figure out where to buy ground bars? The closest thing I could find was this:
http://updates.clipsal.com/ClipsalOnline/ProductInformation.aspx?searchMode=group&first=30&skip=47&code=48002&level=4
Nov 8, 2010. 2:01 AMDagless says:
I'd try electrical suppliers/wholesalers such as Lawrence & Hanson or Rexel. I worked at a similar electrical supplier in New Zealand and we stocked these in varying lengths. We called them busbars (pronounced 'buzz bars'), so they're possibly called that in Australia too.
Apr 9, 2009. 11:54 PMinsanepotato says:
I'm in Australia, would Bunnings have "grounding bars"? I've never seen or heard of them in my life.
I'm planning on using cheap Asian tongue scrapers as tines, since its possible to find some that are almost identical to that blue steel (just not blue), although I'm not sure what I'll mount it on xD
thanks for sharing the idea btw =D
Sep 27, 2010. 5:13 AMspark master says:
Make friends with an electrician who does rennovations a lot, the piece you want is inside a circuit box(panel). It is where we tie down the neutrals in USA we have 110-120 volts ac, not 200-210 v ac . There should be a strip inside the box that has a grounding strip. When we do a rennovation (say pullout a 60 amp or 100 amp house service, the box is garbage and sent to the scrap heap. I no longer do electric work, but people toss them out occassionally. I made a Kalimba with my kid so I will need to look around for one of these.
This is a great idea I never thought of!!! But where does one get better boingers, err reeds. Regular pulling snake is fine for about 8 notes that's it.
thanks
sparkie
Sep 27, 2010. 9:51 PMspark master says:
wow a hot wired kalimba , are the piezo's cheap?
sparkie
Jul 18, 2009. 1:38 AMWarlrosity says:
It is more of a ... Hardware store! Massive,green,amazing! Btw nice work!
Jul 18, 2009. 3:27 AMinsanepotato says:
turns out, they dont have them, so still no kalimba for me haha
Jul 21, 2009. 2:28 AMmmbutler says:
In the Commonweath there's a tendency to use the word "earth" where Americans would use "ground". Insanepotato, you might try to use "earth bar" or "earthing bar" as search terms. Schneider Electric makes them, I think, but even if not, a bit of looking for "electrical supplies" in the phone directory should point you in the right direction. Rexel Electrical is one Aussie company name I have heard. Good luck!
Aug 29, 2010. 11:45 PMwocket says:
i wonder if anyone actually ended up finding some in Australia?
Oct 22, 2011. 6:54 AMcurious.jp says:
Apologies for the late reply. Yes, I did - under the name "earth bars" or "neutral bars". I ordered a handful of brass ones from Metroid Electrical Products in Victoria, and they were in my mailbox the next day. Work well with bike spokes and street sweeper tines, but Australian designs often have a doubled row of holes for attaching the earth wire.
Explain what you want - after I explained it to their sales guy, he provided me with engineering drawings for a variation which isn't on the website.
Jul 18, 2009. 7:43 PMWarlrosity says:
too bad
Jan 2, 2010. 5:24 PMcheveux.boucles says:
That was a great instructable - thanks!  I ended up using hammered-out bicycle spokes as the tines, and a cigar box as the resonating chamber, and it sounds great - especially with a contact microphone right under the bar.  Keep it up.
Aug 31, 2009. 1:37 PMmistic says:
made one years ago- I eventually drifted to stringed instruments- made a mini-zither- but found some minor problems such as boxes giving unusual strange resonances -unwanted discords ,etc. still it plays like a harp and goes nicely with my kalimba. {see my instr- Mini-zither}
Aug 21, 2009. 9:50 AMamplex says:
awesome sounds, i love the creative tines and the difference in tones you get from them, im definitely going to build one of these asap!!!!
Mar 5, 2009. 3:57 AMagis68 says:
Very cool..i will make one five stars...excellent project and well done
Feb 17, 2009. 2:41 AM8bit says:
Five stars! Excellent!
Oct 12, 2008. 2:50 PMImmrwrite says:
This is awesome! I'm on my way to the hardware store right now! finally a use for all those small wooden boxes that tend to collect around me. Thank you very much for a great Instructable!
May 16, 2008. 9:58 PMsarandi says:
I was just thinking...I've seen tines like that somewhere - and then it hit me: Old windshield wiper blades have similar metal inserts! Thanks for the wonderful ideas - the grounding bar is genius. It could also be used to build a stringed instrument!
Jan 24, 2008. 2:29 PMAndyGadget says:
Cycle spokes make excellent keys. Mount them with the mushroom shaped bit pointing up and it's much easier on the thumbs if you're a nail-biter. Tune the thing to C Major (CDEFGABC...) if you want to play 'real' tunes on it, or to a minor pentatonic scale (e.g. ACDEGA...) and any 'improvisation' will sound harmonious. A software tuning aid is essential if your musical ear is anything like mine. The Mk2 version will have a thin wooden top as I suspect ply is not the best choice for a soundboard.
Dec 22, 2007. 7:12 PMaeray says:
Just built one for my brother using the ground bar method, pegged black walnut for the box sides, dense, almost-instrument-grade spruce for the top and bottom, and tines from an old rake for the keys... total cost $6 for the ground bar. Looks good and those I have shown it to who don't have a tin ear like me say it sounds good too. Excellent idea.
Dec 7, 2007. 7:21 PMmcraghead says:
Time to go ground-bar shopping, indeed!
And then... plug it in!
Oct 24, 2007. 6:39 PMestevan says:
i need some suggestions as to where i could get some decent tines. i went to a home depot and my options were severely limited and i was uncertain as to how to describe what i'm looking for in terms of tine material. Any places online i could order materials?
Sep 29, 2007. 8:34 PMjerbob says:
I've seen those streetsweeper bristles on the edges of streets all of my life. What a cool use for them! I used them as a kid to make mini-knives. Most kalimbas are tuned around a Major 7th chord.
Sep 25, 2007. 6:44 PMevil_paul says:
Thank you so much for sharing. I have really enjoyed seeing your creations on Flickr and I can't wait to have a go at making my own.
Sep 1, 2007. 10:13 AMliny says:
nice idea, never thought of using a grounding bar for an instrument. look at mine:
1-40 of 45next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:yapruder
RP Collier artist, musician http://rpcollier.bandcamp.com/album/platz http://cdbaby.com/cd/rpcollier6 http://cdbaby.com/cd/rpcollier5 http://cdbaby.com/cd/rpcollier4
