The thumb piano, known as a kalimba or mbira and by many other names, is a lamellaphone that uses plucked prongs called tongues, keys or tines to generate acoustic vibrations. The length of the tine determines the pitch.
Generally, the thumb piano uses some kind of mechanism to create a great deal of pressure to anchor the tines across 2 bridges which allows the free lengths of the tines room to vibrate. The tines are usually of the same material and gauge (thickness) to ensure consistency so the pressure is distributed equally holding everything in place and in tune.
The method shown here is simplified and wonderfully versatile. It allows the use of more fragile, delicate, and unusual materials for the body of the instrument, and it provides a way to use oddly shaped tines of different materials at the same time while permitting the tines to be swapped out and tuned with ease.
There are interesting possibilities here: a simple armature or jig that becomes a tool with which to investigate the sound that different materials make - how they vibrate, how they resonate and how different combinations of factors can change the sound quality.
Experiment and explore and find configurations that work for you.
More photos:
Flickr set
Video link in Step 6.
Remove these ads by
Signing UpStep 1The Grounding Bar
The bar shown is about 4 1/2 inches long and 1/2 inch in width.
The 3 empty slots are drilled all the way through, this is where fasteners can be used to attach the bar to something.
The way I like to do it is to use a tap to thread the bottom of several of the holes and then screw in place from underneath to free up all the horizontal holes.
Another way is to use speed nuts which are flat, square and springy. You find the size that fits in the hole, screw in from the top down past the horizontal hole and use a hex nut to again anchor from underneath. Then the top of the anchor screw becomes the floor of the set screw.
I'm sure there are other ways people will come up with as they experiment. This instructable was trying to keep things as simple as possible.
Para los amigos hispanohablantes: la pieza se consigue como Bloque De Terminal de metal o latón o Barra Terminal de latón, o Bloques de Tierra de 8 vías (o de las vías que sea dependiendo del nùmero de hoyos) está catalogado en la electrónica como accesorios de puesta a tierra, por eso en inglés lo llaman Grounding Bar.
Espero que les haya servido la informaciòn, realmente es un instrumento hermoso y vale la pena hacerlo!
http://updates.clipsal.com/ClipsalOnline/ProductInformation.aspx?searchMode=group&first=30&skip=47&code=48002&level=4
I'm planning on using cheap Asian tongue scrapers as tines, since its possible to find some that are almost identical to that blue steel (just not blue), although I'm not sure what I'll mount it on xD
thanks for sharing the idea btw =D
This is a great idea I never thought of!!! But where does one get better boingers, err reeds. Regular pulling snake is fine for about 8 notes that's it.
thanks
sparkie
Using a piezo pickup should help expand the range. There are some instructables and Youtube videos that describe how to build one.
sparkie
Explain what you want - after I explained it to their sales guy, he provided me with engineering drawings for a variation which isn't on the website.
http://www.suddensound.com/workshop/samples/hammeredkalimba.mp3
Courtesy of Greg Bossert of Suddensound.com:
http://www.suddensound.com/workshop/hammeredkalimba.html
And then... plug it in!
