Step 2Primary Keyboard Layout
This is the plan view of a primary keyboard layout. Almost all of the keys required for normal English typing are present. Other characters are found on one or more alternate keyboard layouts, which are accessed by a mouse (or other input device).
You might immediately recognize that the letter keys are arranged alphabetically, and broken down into groups that each begin with a vowel. The entire alphabet is within reach of one hand.
This keyboard works in conjunction with a mouse having a middle scroll-wheel button. When the wheel button is pressed, an alternate keyboard layout is displayed on the screen, in front of all other applications. (An example of a screen layout is shown in Step 3.) When this occurs, the alternate character set shown on the screen becomes active. In essence, the wheel button acts as an additional keyboard control character.
(Hereafter, the terms character-set and layout may be used conjunctively.)
In addition to the letter keys, there are the familiar editing keys and keyboard control keys (CTRL, SHFT, ALT). These auxiliary keys are present in this primary layout, as well as all other layouts.
The wheel button is used to instruct the operating system to accept alternate layouts, while using a single keyboard. This keyboard system is designed to configure the English alphabet in an intuitive arrangement, without requiring the user to remove his or her hand from that arrangement to use the mouse (or other input device).
The primary keyboard layout is posted here for reference only. It would not be required as a screen layout.
I follow your thinking on the digraphs and such. However, from a marketing standpoint, this would have to appear simple to learn, otherwise it would be a bust. (Case-in-point: Data Hands)
So, having at least the consonants arranged in alphabetical order is as good as any layout (especially if they can digraph with a row of vowels) and it will be learner-friendly.
From http://www.sectorsoftware.demon.co.uk/typist.htm
"Unless you learn to type faster without looking at the keyboard or at you hands then you are the most inefficient part of your computer system and are wasting part of your life." (Emphasis mine.)
Have you ever had a lesson in typing? Have you ever noticed the little bumps under your index fingers when they are sitting on their home keys? Do you know what the home keys are?
If you are using a qwerty keyboard, you home keys for the left had are "A-S-D-F' and for your right hand they are "J-K-L-;". Qwerty keyboards generally have bumps on the "F" and the "J" key. They are there so that your sensitive index fingertips can find their home keys.
Take some online lessons. Improve your typing skills.
But, all "F'n'J"ing aside...I think the majority of us rely on those special keys, we just don't take as much pride in it. I've thought for a while, though notwithstanding pricing concerns, that every key should be "texturized" in some unique and readily identifiable way...hence, Raised Letter Keys:
P.S. have you ever noticed that "werf-jiop" would be a more ergonomically-correct home row?
Yeah, I'm not sold on the exact location of the space "bar" either. But, the hump in the palm area represents a support, which can be heightened as needed. I like your thought on side keys. We've agreed that the existing thumb keys can be placed in more of a horizontal line, if nothing else. Even an arc that follows the lateral path of the thumb, would provide a swath of keys on roughly the same plane as the finger keys.
Key placement has been the great debate. And, yes, ergonomics definitely come into play, so as to avoid a grossly overdeveloped left forearm. But let's face it. I think most people could stand to beef up their left arm at least a little bit. ;>)
Thanks for the feedback. You've helped me arrive at an interesting notion...
And in light of this new development... Cool! I saw something using the same "key in-between keys" design a while back. They used it for the world's smallest keyboard, (smallest back then) I can't seem to find a link for more info cause it's probably old-school technology now. I think they based it around a touchscreen panel, with software to work out which key was pressed. Of course, button design will have to be CRITICAL for this to work.
When I first looked at your diagram, I saw six rows, and I immediately thought. Ouch. That must be a pain to type with. This is definitely better. Less movement = Less Ouch.
Though I don't believe that the alphabetic layout will be easier to learn than any other. Personally, I reckon learning to type is kind of like conditioning. In that I think "b", and my finger moves a certain direction to B, and I do this so many times that the letter becomes associated with the movement. So with practise, typing becomes nothing more than muscle memory.
Irrelevant of the layout, to become naturally familiar with the keyboard, you will have to spend time consciously thinking about key positions while typing, thus causing you to slow. I think that it's this process of actually thinking that slows you down. For about two weeks, I knew where every letter was, but sometimes I'd get a mind blank, and have to think "B? Where's B... Oh. It's here."
I simply think that to learn a new keyboard layout will be extremely painful from the words-per-minute side of things, irrespective of how intuitive it is.
Cheers.
