Introduction: Snowboarding - Instructable Robot Stomp Pad
Picture of Snowboarding - Instructable Robot Stomp Pad
Getting off the ski lift can be tricky at sometimes if you are a Snowboarder. Ahh that is why it is called a Ski Lift !!
Prevent those nasty falls by following this ible and 3D print your self a Stomp Pad.
The Stomp pad is of 84 millimeter(3.3 inches) in diameter, which sticks at the side of you binding to give you snowboarding boot to grip on.
Or if you are a Pro you can showoff your 3D printing skills with this unique Instructable Robot Stomp pad.
Step 1: Select the STL File to Print
Picture of Select the STL File to Print
Select the design which matches you style , and download it to your local hardisk.
#1_StompPad_Simple.stl
#2_StompPad_boxDown.stl
#3_StompPad_withHoles.stl
Step 2: 3D Print the STL File
Picture of 3D Print the STL File
Download the 3D printing software that you printer supports, in my case I am using the Printrbot Simple Metal which use Repetier-Host as a software to
  • Slice the STL files attached,which basically means cutting the part into various layers
  • And send commands to the 3D printer while printing
In my case I am using the following filament
HATCHBOX 1.75mm Yellow PLA
Once you have decide on which design suits you best -
  • Slice the file this should take about 13-15 seconds
  • And printing the file should take about 17-20 mins and is dependent on your printer settings.
Step 3: Dry the Spot on the Snowboard
Picture of Dry the Spot on the Snowboard
Dry the spot and get rid of any dust with a clean cloth near the binding where you plan to stick the 3D printed stomp pad.
Use a blow drier, if you have one handy to get the spot nice and dry.
Step 4: Stick the Stomp Pad to the Snowboard
Picture of Stick the Stomp Pad to the Snowboard
Once the spot where you are going to place the Stomp pad is nice and dry you are now ready to use an adhesive to stick the Stomp pad to the Snowboard.
Congratulation your done !! Enjoy riding the fresh powder and prevent that nasty fall while getting off the Ski lift..
kgarcia21 (author)2015-02-22
Ruler, it's just extra traction for when your getting of the lift and your one foot isn't in its binding
Ruler1324 (author)2015-02-22
How does this work? I have know idea what this is
CJA3D (author)Ruler13242015-02-23
Thanks for the comment ,I will try and capture a video when I get to Snowboarding over the weekend to show its functioning..I think i will have to borrow a GoPro from a friend to do this..
About This Instructable
2,974views
22favorites
License:
Bio: Born as a farmer, studied electronics ,working as a Consultant and a 3D printing enthusiast by night..
More by CJA3D:Pi Hidden CameraBOSEbuild Speaker Beat CubeIoT Globe
Add instructable to:
