So here's how to make one. :D
Remove these ads by
Signing UpStep 1Materials
Things you'll need for sure
- Green foam florists use. ($1.48 for 3 pieces that are 3.5" by 3.5" by 3") This stuff is fun to cut up and is very easy to carve things out of. Don't use styrofoam, it isn't as easily carved. Be sure that it's thick enough to carve a 3D thing out of it
- Plaster of Paris ($3.97 for 4 pounds at some hardware store)
- A picture of the Instructables robot. Make sure it's not too big.
- An X-acto knife. This is what I mostly used to carve the foam with.
- A plastic cup and fork for mixing the Plaster of Paris. You might want to have some water for it too.
- A few paint brushes. Make sure at least one of them is one you don't care about at all because it will probably get ruined.
- Paint. You'll need some yellow and a little bit of red and gray. You might want to make his arms legs and head a bit more orange-ish
- A steak knife
- Maybe a pair of scissors to cut out the picture of the robot
- A metal barrette like the one in my picture. It helps for cutting the foam out from between the robots legs.
- Sandpaper
- Newspaper! Clean-up will be SO much easier. But it's really hard not to get green foam pieces everywhere even with newspaper. Especially if you're outside and it's windy...
- Pins
![Robot car tracking line [ easy way ]](http://img.instructables.com/files/deriv/F37/7PCL/GGPET5NH/F377PCLGGPET5NH.SQUARE.jpg)
Okay, I thought this wasn't featured for a second! Nice work!
L
