3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Instructables Text Formatting
Step 8Character Entities and Extended Codes
Note: The IbleFormatter does not handle character entities well. If you use entities, and go back to re-edit the text, some of them will be "stuck" as embedded special characters, which will subsequently have extra "garbage" characters attached to them.
HTML (and the I'bles Formatter) provides named "entities" for a number of characters beyond the normal keyboard (ASCII) set, using strings of the form "&name;". These (the ISO Latin-1 character set) cover primarily the Western European languages with accents and umlauts, and some simple mathematical symbols. The left table, below, shows the ASCII codes, with entity names for a few characters.
The same characters (and even some normal ASCII) are also available using their numerical codes, as "&#code;". All of the ISO Latin-1 characters, with their codes and entity names, are listed in the right-hand table, below.
If you think you've seen this before, you're experiencing déjà vu.
& amp;eacute; - & amp;agrave;
To put literal brackets into your text [rather than hyperlinks], use ASCII codes 91 and 93.
& amp;#91; - & amp;#93;
HTML 4.0 also supports the full Unicode set of characters, with numerical codes greater than 255. These include the non-Latin European alphabets (Greek, Cyrillic, etc.) as well as numerous Asian character sets. For more info, check out these links:
Here are some of the codes and what is displayed.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
55
Author:NachoMahma
Just another poor slob, trying to make it to the grave with as little hassle as possible. . Humor is the only test of gravity, and gravity of humor; for a subject which will not bear raillery is susp...
more »
