This is a very useful skill, because often there's no can opener to be found.
In fact, there were fifty years when cans HAD to be opened without a can opener.
W'pedia sez:
"The first tin cans, invented in 1810, were heavy-weight containers that required ingenuity to open, using knives, chisels or even rocks. Not until cans started using thinner metal about 50 years later were any dedicated openers developed."
You can also watch the video on Blip.tv. Have a preference as to which service you like better? Send a private message to noahw or leave a comment.
Remove these ads by
Signing UpStep 1Advanced Technique: Open Can with Ballpoint Pen
A Bic ballpoint with the hard clear body as seen here is good for this.
Some pens are made of soft plastic that isn't as good. This old model is great. It survives salt water and all kinds of abuse. The ink doesn't run when it gets wet. I liked it better than an "astronaut" pen that failed on the same trip.
Open Can with Pen:
1: Using a corner of the pen's blunt end, score the can across top. This makes a big "X" in the top of the can.
2: Stab a hole in the middle of the top with ballpoint. This is easier than it sounds.
Now there's a hole in the middle of the X. A hole with four corners.
3: Enlarge the rips in the four corners. Push each corner along with the handle of the pen til it reaches the edge. Pry up each flap.
4: Eat contents with two sticks as chopsticks. Plan uses for the interesting metal thing you have left.
![[Collegiate Meals] Two Way Tuna Sandwiches](http://img.instructables.com/files/deriv/FRB/UV8L/FGHEXCFCKP9/FRBUV8LFGHEXCFCKP9.SQUARE.jpg)
The knife used must have been really blunt otherwise it would have ripped open the guy's palm.
One of the first things parents teach their kids in the kitchen is never to cut towards yourself. Always cut away from your body.
The video and advice is irresponsible. Kids might not know you are trying to be funny and actually try it.
step 1: find a can and a knife
step 2: stab the top of the can in
step 3: eat (_)
