Instructions to Build 8x8x8 LED Cube
9,584
62
10
Posted in TechnologyArduino
Introduction: Instructions to Build 8x8x8 LED Cube
This LED Cube is a cool device that enables you to see in three dimensions, and has 512 LED's for 8 layers of 8 rows and 8 columns (8x8x8).
This work requires a lot of soldering. It will be very interesting for sure. You can just follow my instructions to complete this build.
LED cube kit can be purchased from this link
Step 1: Gather the Requirements
Step 2: Draw a Table (7x7) With Squares of 2 Centimetres Each Sides
This is the first step in preparing the fixture. I may have more squares but a table with 7 rows and 7 columns were enough.
Step 3: Stick the Paper to the Cardboard or Ply-wood
Step 4: Make Indentation With Steel Scriber for Easy Drilling
Step 5: Use 5 Millimetre Drill to Make Holes
To accommodate the 5 mm LED's
Step 6: Insert the LED's & Make Sure the Cathode Terminal Is Aligned Out Side
Cathode terminals can be easily identified as shorter
Step 7: Trim and Bend the Cathode Terminals
Step 8: Solder All the Cathode Terminals
Step 9: Bend the Anode Terminal Using a Spacer of Thickness 2 Millimetre
Step 10: Solder the Anode Terminals
Step 11: After Soldering, Carefully Remove the LED's From the Fixture
Step 12: Prepare 8 Units in Total
Step 13: Carefully Insert the LED's to the Female Header Pin's on the Board
Step 14: ​Connect the Common Cathode Terminals of Each Layer (please Find the Notes in the Image)
Step 15: Connect All the Common Cathode of Each Layer to the Hoard
Step 16: The Build Is Complete Now. You Can Power Up the Cube (5 Volt or Through USB)
Step 17: Link to the Software and Program Codes
github.com links Click here (USB to TTL drivers, keil, STC ISP and others)
gearbest links Click here (.hex and c files)
Step 18: This Video Will Be Helpful
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
    10 Comments
    Hey, I ordered this from GB around a month ago and received it a few weeks back, upon it arriving I googled for instructions on how to build this and found your YouTube video, it was a great help and I managed to get a working cube within a week ( I did a few 8x8 grids per night as time is limited) after finishing everything and testing I found it wasn’t at all what I expected, the test patterns just didn’t seem right, anyway I left it for a week and came back to it today, I realized what you had done and went abut rectifying my build, now the cube displays as expected and upon watching your tutorial back I’m surprised no one else has noted the error.
    You need to swap your anode and cathode’s around, this will give you the correct test sequences, if you watch the first 20 seconds of your video you notice how all the leds are lit up and there’s some that turn off, that should be the inverse of this with all led’s off and a few led’s producing a spinning pattern.
    Again I want to to thank you for this tutorial as without I wouldn’t have known where to start.
    To anyone else not getting the results they expected, you don’t need to do a full strip down to rectify only take it back to the 8 separate 8x8 grids and solder on some legs for the anode connections and rebuild from there, it took no more than 1 hour to strip and get this working as should be.
    Thanks Damien, Your comments means a lot. Soon I'll fix and upload the tutorial.
    I have just been given one of these kits. Am I right that instead of the cathodes being bent down to go into the header pins it should be the anodes? (I am going cross eyed trying to follow the tracks)
    Yes, You're correct. I made the mistake. There is "NO" proper instruction manual was available.
    amazing efforts man.
    very well explained instructable.
    is they are small videos or gif files.
    this this is one of its kind instructable with lot of videos/gif.
    thanks for sharing :)
