Introduction: Insulate the Back of Your Solar Panel!
Picture of Insulate the Back of Your  Solar Panel!
Just got a goal zero solar panel. It's pretty cool. But. The instructions say not to charge devices when they're in the handy back pocket cuz they'll get super hot. :( This should work for any solar panel that has a pocket in the back to charge devices.
Step 1: You're Not Supposed to Charge Stuff When It's in the Pocket
Picture of You're Not Supposed to Charge Stuff When It's in the Pocket
Well. The back pocket is handy. And I wanna put stuff in there and not have my phone or battery pack overheat. This is my solution
Step 2: Get Some Magic Sunshade Stuff
Picture of Get Some Magic Sunshade Stuff
I had mine leftover from another project
All you need for this project:
Sunshade material
Skizzors
Double bubble stick tape
Step 3: Cut It Out
Picture of Cut It Out
Into the shape you need that will just snugly fit in the pocket. This takes some trial and error
Step 4: Test Fit
Picture of Test Fit
See where I had to cut out a bit for the charge port? Yeah.
Step 5: Put Strips of Double Stick On
Picture of Put Strips of Double Stick On
This might be unnessicary um... unnecessary (hate that word) but you get the picture.
Step 6: Done!
Picture of Done!
And isn't that carpet fabulous?!
Now you still shouldn't charge items in the back pocket but if you accidentally did they, in theory would be a lot cooler. Yah.
Yonatan24 (author)2016-07-30
I don't understand what you did here. Solar panels need to stay cool in order to be more efficient and last longer :)
josh (author)Yonatan242016-08-02
Hi Yonatan24, you're right, in this case the panel back is already covered in fabric which insulates the panel, the purpose of this hack was to protect accessories, (iphones and battery packs) from the heat while they are charging. exploding batteries = bad. The efficiency reduction will probably be minor. Have any ideas how I could keep the panel itself cooler? Thanks!
Yonatan24 (author)josh2016-08-02
Oh... That makes sense!
I don't know... Maybe glue some sheet metal onto the back? That might help a bit...
About This Instructable
753views
11favorites
License:
Bio: Traveler
More by josh:Wildernest Tent Frame Replacement and UpgradeDandelion Clock In ResinReplace Water Bladder Hose Cheap!
Add instructable to:
