This Instructable describes an innovative way to build walls using bamboo or wood saplings and bags of insulation. We’ll be using bamboo for this Instructable since it is rapidly renewable, low cost and readily available in many parts of the world. Let’s start with some background information to better understand what is involved.
People often wonder how to build interior walls on earthbag and strawbale homes, which are about 18” wide once plastered. These building methods create strong, stable walls that are ideal for exterior walls, but they take up too much space for interior walls. Thinner walls are preferred.
There are numerous ways to build interior walls. The most common method -- wood framed walls -- has numerous drawbacks. Lumber is expensive and, at least in the U.S., is often harvested from unsustainable sources that devastate forests and then shipped hundreds or even thousands of miles. Awareness of this issue is creating a growing demand for more sustainable and lower cost alternatives. (Plus, a lot of the wood being sold nowadays warps and twists badly.)
The following suggestions may not meet building codes where you live. Always check with local building authorities before you begin any building project. There are still quite a few areas with minimal codes, and this article is written for those who are free to build as they please. Join the discussion on Counties with Few or No Building Codes.
Here’s a short list of low cost, sustainable interior wall options:
- wood pallets or recycled wood: they can be filled with straw/clay (straw mixed with a slurry of clay) or other types of insulation for soundproofing
- locally sourced peeled wood poles milled on one side, possibly using a chain saw milling guide or power jointer
- wattle and daub: mud-covered woven branches is one of the oldest building methods known to man. Straw can be added between the branches for soundproofing.
- insulated bamboo walls (the method discussed in this Instructable)
Insulated bamboo wall summary: The general process involves tying or lashing bamboo frames together – one frame for each side. Burlap or poly bags with insulation are sandwiched between the frames and tied together. The finished wall is plastered with earthen plaster or lime plaster. Here's a short YouTube video that shows the main steps.
Primary benefits: Extremely low cost (could be built almost for free if you have a source of bamboo and free or recycled bags); simplicity of construction (only a few tools are required, and the process is simple enough that anyone can do it); soundproofing between walls using rice hulls or other types of insulation in the bags; non-toxic (no offgassing of toxic fumes); finished interior walls match plastered earthbag walls; you can run electrical wiring through the wall and attach electrical boxes to the sides of bamboo poles.
Tools and supplies: Saw, tape measure, level, galvanized wire or baling twine, wire cutter pliers if you use wire, knife if you use baling twine, insulation, polypropylene or burlap bags, 1”-2” diameter bamboo or saplings, deck screws and drill
The photo shows a small prototype.
Remove these ads by
Signing UpStep 1: Build the frames
Once you’ve decided where to put your walls, the first step is to build the frames. A good size for interior walls is 1-1/4” vertical bamboo by ¾” horizontal bamboo. Use larger 2” bamboo on exterior walls. Measure and cut the bamboo to length, and assemble the walls on the floor or preferably on sawhorses with boards set up between. Cut the bamboo about ½” shorter than the space it’s going in so you can tilt the wall into place. The drawing shows the frame tied together with a space left for a door. (We’ll cover the door in the last step.) Build the frames using a convenient spacing that matches the size of your bags. In this case we’re using bamboo set on a 24” x 24” grid to match 24” wide bags. Note: inset perpendicular bamboo pieces about 2” around the perimeter to allow space for lashings.
Tie frames together with twine or wire.
Twine method: Use a knife and baling twine or cord. Twine or cord is easier to use than wire. Lash the bamboo together with square lashings as explained on Wikipedia . The second photo below shows a square lashing on wood poles (always peel the bark off first).
Wire method: Use wire cutter pliers and approximately 16 gauge galvanized wire. Twist the wire until every joint is tight.
Note: The drawing shows lashings as "short ties."
You’ll also need to add longer ties for joining the two frames together. Space the long ties in a grid about 2’ apart, and make sure you allow enough length to tie knots. Twine length will depend on the width of the wall and the tying method. Experiment a bit to see what works best for you. Assembling the walls on sawhorses makes it easier to tie the frames together, which is discussed in Step 3.
Visit Our Store »
Go Pro Today »
would plastic bags or shredded plastic be a good filler in bathroom, kitchen, kitchen, and basement walls? not that natural isn't nicer, but it just seems like a reasonable use for any such junk that isn't recyclable. if it wouldn't off gas--I don't know. the bags especially would be light and a good shape.
also rags might be good--though not in a wet area of course. the entire structure rather seems like a quilt so I guess fabric comes to mind. if one happened to have large pieced to reuse, an actual quilt might be a good option for the yurt or other curved walls. piece together two sheets that match your wall's elevation, spread out the insulation on one, cover and then tack them together with stitches or staples. when finished wrap it around the lattice then tie on an external set of poles/slats.
wouldn't this be good for ceilings also?
could you fireproof it enough to not need plaster? burlap and natural twine could be a good look if done as neatly as your picture. or painted. perhaps not right for every room, but an option.
what about building an open plan house, then once it has passed inspection construct these as freestanding room dividers--furniture, not architecture. also a flexible floor plan. ; )
this is very exciting idea I hope some day to be able to use.
- incorporate certain aspects of quilting (sure, why not)
- insulated ceilings (yes, but fire resistance is very important)
- combine aspects of yurt lattice with insulated walls
- build interior walls later after the inspectors are gone
But I wouldn't want much plastic in the house. As far as I know, all plastic offgasses at least a little. You can buy cotton insulation made from recycled jeans, so why not make your own?
Also what kind of insulation do you suggest?
Thank you once again!
