Insulating Laptop Pad
When using a notebook/laptop computer actually in your lap, the heat buildup can get annoying. This pad is meant to insulate you from the computer-generated heat, while still allowing it to dissipate heat from below.
Step 1Cut the insulation
Cut the insulation
I used extruded polystyrene (XPS) insulation board (the pink stuff; the blue stuff and green stuff are similar). I would not recommended expanded polystyrene (EPS) board--the white coffee cup foam--it tends to crumble when cut.
Note that you can cut XPS by scoring it about halfway, and snapping it.
12 comments
Apr 20, 2009. 12:28 PMPostlane says:
I tried to make a notebook pad that I could use professionally while travelling but decided it was just easier to buy one. I decided on a ThermaShield RFI because it protects from radio waves (WiFi, Bluetooth) as well as heat.
http://axonics.net/html/laptop_protection.html
It is lghtweight, portable, does not use batteries, and packs easily for my travel. It keeps my notebook computer and lap cool. Anyway, that's my 2 cents!
Mar 17, 2009. 1:34 PMlukkbox says:
nice work fella i used a plastic breadboard covered in 3 layers of tinfoil then wound up with duck tape works a treat and keeps microwaves off ya nuts!
Sep 5, 2006. 1:47 PMleevonk says:
studies have shown that heat from laptops (if you use them on your lap) causes lower sperm counts. So, good work.
Jan 22, 2008. 6:33 AMbrandonssk says:
Actually There have been a Good number of Laptop batteries exploding inside of the laptop and destroying it because the battery was insulated.It would probably be wise to add a heatsink to this insulator.
Jan 22, 2008. 7:18 AMleevonk says:
I believe a fan counts as a heatsink (see my comment below)
Sep 5, 2006. 1:53 PMleevonk says:
a hole could be cut in the center of the styrofoam/plastic and one of these (http://www.instructables.com/id/E5EU54XP26EP2871HG/) USB powered fans could be put in there to help keep your laptop cooled (for it's own health). Then when you put your laptop on the thing, you just plug in the usb fan, you and the laptop stay cool and healthy.
Sep 24, 2006. 1:44 PMBU5T4 says:
I have a tray thing that does that exact job here at home. Its made out of alloy and has two fans built into the bottom of it. It also has two USB ports on it that stops you from losing a usb from plugging this device in. It isnt designed very well however as it was made to sit on your desk and not on your lap so its very uncomfortable, i think your idea would work much better than this one. Thanks for a great instructable buddy. Great work.
Sep 20, 2006. 1:58 PMAMalePoet says:
How about a dimple mat (Or simular substance) sandwich? Assuming you don't have one of those light up laptops. After all the stuff vents and drains right? Oh and for a cover a spandex sleave would work nicely. As I knew a guy in the 90's that used the stuff in a hack that allowed him to wedge his portible CD player using foam rubber in his VW van dash. He even included wire access in the back to hook up to his car stereo. Besides it can come in so many colors
Sep 15, 2006. 1:52 PMbluerover says:
Our local dollar store has plastic tiles at$1 each. 12x12 and interlocking they would make an idea mat.
Sep 13, 2006. 9:30 AMbrauhaus says:
I would certainly want to cover the foam with something to prevent (possibly toxic) bits from shredding off. Might also extend the life of the foam.
Sep 4, 2006. 12:15 PMtrebuchet03 says:
great first instructable
Sep 4, 2006. 8:34 AMtinglystix says:
nice job man
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:Bats22
Building energy efficiency/construction industry consultant; woodworker; casual (not hard core) cyclist.
