3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Insulating Laptop Pad
Step 2Cut dimple mat
Cut dimple mat
I am in the building research field, so I have some of this plastic 'dimple mat' hanging around my lab. This product is typically used to waterproof foundations--it creates a drained air space, so that any water that gets in drains out.
The idea for this piece is to space the laptop off of the insulation board, with a ventilated air space underneath. Admittedly, you can use a laptop on a table or a bed without a problem, but I figure more cooling=better.
The dimple mat comes from a company called Cosella Dorken; another company that makes a similar product is System Platon. Unfortunately, you might have a hard time finding it--I have seen Platon at only a few Home Depots. It also comes in big rolls--way too much for the project.
A similar product that you might be able to use is Dri-Cor; I have definitely seen this at a lot of Home Depots--it is 2'x2' squares that you lay down on your basement floor, to create a warmer/dryer floor.
1 comment
Sep 15, 2006. 1:52 PMbluerover says:
Our local dollar store has plastic tiles at$1 each. 12x12 and interlocking they would make an idea mat.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:Bats22
Building energy efficiency/construction industry consultant; woodworker; casual (not hard core) cyclist.
