Introduction: Integrated Weather Station (IWS)
Picture of Integrated Weather Station (IWS)
In this project, we will be making an Integrated Weather Station (IWS) that measures multiple parameter (air pressure, temperature, rain drop, soil humidity and air humidity) using Arduino, interfacing parameter with Nuvoton, and plot the data with Raspberry Pi.
It’s a quite complicated project and need some basic knowledge requirement, which is:
  1. Arduino with Sensor Setup
  2. Arduino - Nuvoton Communication
  3. Arduino - Raspberry Pi Communication
  4. Raspberry Pi - Data Plotting
  5. Raspberry Pi - Data Logging
  6. Raspberry Pi - Real Time Clock (for Data Logging)
Step 1: List of Material
Picture of List of Material
For this project, we will be using:
- Arduino boards (mine Arduino Uno Rev3)
- Nuvoton NUC140
- Raspberry Pi
- Flash Drive cost:~5.00 USD
- Real Time Clock (RTC) Module cost:~3.00 USD
- DHT11 Humidity and temperature sensor cost:~5.00 USD
- BMP185 Barometer sensor cost:~6.00 USD
- Rain Drop sensor module cost:~2.00 USD
- Soil Humidity sensor module cost:~2.00 USD
- Breadboard or Custom ProtoShield
- Jumper Wire
Step 2: Hardware Connections
Picture of Hardware Connections
  • In general, the connections are very simple. Follow the instructions and images above, and you should have no problems.
Arduino Connections :
Connecting Rain Drop Module
  • the VCC pin on Arduino’s 5V output
  • the GND pin to Arduino’s GND and
  • the Analog Data to Arduino's analog pin 0
Connecting Soil Humidity Module
  • the Analog Data to Arduino's analog pin 1
Connecting BMP185
  • the VCC pin on Arduino’s 3.3V output
  • the SDA (Serial Data Line) pin to Arduino’s analog pin 4 and
  • the SCL (Serial Clock Line) pin to Arduino’s analog pin 5
Connecting DHT11
  • the DATA pin to Arduino’s digital pin 4
Nuvoton Connections:
  • Connect Arduino Transmitter pin (TX) to Nuvoton Reciever pin (PB0)
  • Connect Arduino GND pin to Nuvoton GND pin
Raspberry Pi Connections :
Connecting Necessary Module
  • Arduino USB Plug to Raspberry's USB Plug
  • USB Wifi Dongle to Raspberry's USB Plug
  • USB Flash Drive to Raspberry's USB Plug
Connecting RTC Module
  • the VCC pin on Raspberry's 3V pin (P1-01)
  • the GND pin to Raspberry’s GND (P1-06)
  • the SDA (Serial Data Line) to Raspberry's pin 3 and
  • the SCL (Serial Clock Line) to Raspberry's pin 5
Step 3: Microcontrollers Programming
Picture of Microcontrollers Programming
Below is the Integrated Weather Station code. Upload IWS.ino code to your Arduino, IWS.c code to your Nuvoton, IWS.py code to your Raspberry Pi, and you should have no problems.
You could clone and edit the code in any way you prefer.
Step 4: Monitor Your Weather Station
Picture of Monitor Your Weather Station
There are 2 option for monitoring your Integrated Weather Station:
  1. Open any device that connected to the internet and open your file-well on Plotly
  2. Unplug your Flash-drive and plot your data using Microsoft Excel
    (Check it our how to read data logger)
Step 5: Enjoy!
Picture of Enjoy!
The final test is to determine if the Weather Station is keeping data log and program survive-ability when internet connection down. The best way to do that is to :
  • Remove the network connection
  • Leave it overnight
  • Remove USB Flash Drive
  • Read & Plot Data Log in your Personal Computer (PC)
After making sure that everything works smoothly, you can take this project into bigger project.
AaravM (author)2017-05-06
hi can i use the dht 22 sensor instead of the dht 11 you are using what will be the change in cod and circuit pls tell i am a beginner
VictorF56 (author)2016-03-09
Hello where can I buy the
Nuvoton NUC140
????thanks
AdrieSentosa (author)VictorF562016-05-31
nuvoton is a rare board nowadays. you could find similiar ARM type board like STM32. But if you really want it so bad you could ship it directly from taiwan. just contact here
http://www.nuvoton.com/hq/contact-us/?__locale=en
gdsmit1 (author)2016-05-18
Thanks for the 'ible.
Any part numbers or sources for the Rain Drop sensor module or Soil Humidity sensor?
AdrieSentosa (author)gdsmit12016-05-31
you could find it in ebay, amazon, etc. but actually you could make your own sensor. Both sensor use capacity sensor principle.
AdityaB1 (author)2015-12-07
rain drop nya satuannya apa gan?
Bukannya dia cuma mendeteksi adanya air atau tidak kan ya
AdrieSentosa (author)AdityaB12016-01-18
maaf baru membalas gan, rain drop nya itu deteksi kapasitas jadi kalau air hujannya cuma gerimis nilainya beda sama hujannya deras.
About This Instructable
20,418views
87favorites
License:
Bio: A candle loses nothing of its light when lighting another
More by AdrieSentosa:LED Acrylic Trophy / PlacardRaspberry Pi - Remote Desktop ConnectionIoT Service Robot
Add instructable to:
