Intel
Published
Introduction: Intel
signing-xdk-apps
Writing applications for android is always fun.
I am going to give a brief summary on manually signing android apps
Step 1: Check Java Version
Open command window and type the following command
$ java -version.
if output is less tha 1.6.
Update the java version to java 6 and above
Step 2: Generate Keystore
use the command:
$ keytool -genkey -v -keystore PATH/TO/YOUR_RELEASE_KEY.keystore -alias YOUR_ALIAS_NAME -keyalg RSA -keysize 2048 -validity 10000.
Where:
"PATH/TO/YOUR_RELEASE_KEY.keystore": is the path in which you want to store the file and "YOUR_ALIAS_NAME": is the name of keystore remember.
Step 3: Attach Keystore to the Unsigned Android App
Type this command:
$ jarsigner -verbose -keystore PATH/TO/YOUR_RELEASE_KEY.keystore -storepass YOUR_STORE_PASS -keypass YOUR_KEY_PASS PATH/TO/YOUR_UNSIGNED_PROJECT.apk YOUR_ALIAS_NAME. Where PATH/TO/YOUR_RELEASE_KEY.keystore: The path to your keystore. YOUR_STORE_PASS: is the password you selected when you created a keystore.YOUR_KEY_PASS:This should be the same as YOUR_STORE_PASS unless you have changed it.PATH/TO/YOUR_UNSIGNED_PROJECT.apk:is the path to your unsigned app. YOUR_ALIAS_NAME: is the alias you selected when you created a keystone
Step 4: Verify That App Is Signed
$ jarsigner -verify -verbose -certs
    • Clocks Contest
      Clocks Contest
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    This is really interesting! Thanks for sharing your info on Android!
