Introduction: Intel Edison Hydroponics Controller
Creating a IoT enabled Hydroponics Controller using the Intel Edison during the Boston IoT Hackathon
Our Goal:
Within a 36 hour hackathon to construct a controller to use with our previous instructable (Vertical Hydroponic Farm). The controller will leverage the sensors found in the Grove Starter Kit Plus - Intel® IoT Edition, some additional sensors we provided (pH,ec) and an Envioronmental Kit Intel had on site for the event.
Step 1: Sensors
What's Inside the Grove Starter Kit Plus - Intel® IoT Edition:
- Base Shield v2
- Grove - Buzzer (more info)
- Grove - Button (more info)
- Grove - LED (more info)
- Grove - Rotary Angle (more info)
- Grove - Sound Sensor (more info)
- Grove - Smart Relay (more info)
- Grove - Temperature (more info)
- Grove - Touch Sensor (more info)
- Grove - Light Sensor (more info)
- Grove - Mini Servo (more info)
- Grove - LCD RGB Backlight (more info)
- 8GB Micro SD Card with an SD Card Adapter
- 9V to Barrel Jack Adapter
- 26mm 26AWG Grove Cable
- Micro USB Cable
- Serial Cable
- Ethernet Cable
Enviornmental kit - provided by Intel Roadshow
- Grove 1/4" Water Flow Sensor (more info)
- Grove Dust Sensor (more info)
- Grove Dry Reed Relay (more info)
- Grove Water Sensor (more info)
- Grove LED Bar (more info)
- Grove Moisture Sensor (more info)
- Grove Gas Sensor (more info)
- 6V Mini Water Pump (more info)
- Grove Digital Light Sensor (more info)
- Grove UV Sensor (more info)
Additional Sensors/Parts
- RoboMesh analog pH sensor
- Conductivity Sensor (EC)
- 12V DC Peristaltic Dosing Pump
Step 2: The Plan
We wanted to implement the base functionality to add automation to our previous instructable (Vertical Hydroponic Farm) which would include;
- water cycles
- by timers
- light
- by timers
- by measurement of natural light and augmenting to maximize throughput
- by fetching current observed weather from weatherunderground.com and augmenting
- temperature
- by measurement and corrective action via a fan and louver
- nutrition
- by measurement and corrective action via nutrient dosing pump
- water quality (pH)
- IoT Integration
- data collection
- all measurements and actions recorded to the cloud for analytics
- alerting
- all measurement data is available to create alerting rules from the cloud
- corrective actions
- all measurement data is available to create rules from device specific corrective actions the cloud
- data collection
Step 3: The Build
We utilized Intel's XDK IoT Edition. It allows you to write your code in JavaScript using Node.js libraries.
The software can be found at Intel XDK IoT Edition, there are many documents regarding how to get started with the IDE.
Coding:
Timers
function setSecondsTimer(waitTime)<br>{<br> var endTime;<br> var d = new Date();<br><br> endTime = d.getTime() + (waitTime * 1000); // convert back to milliseconds from seconds<br> return endTime;<br> <br>} // setSecondsTimer<br><br>function setMinutesTimer(waitTime)<br>{<br> var endTime = 0;<br> var d = new Date();<br><br> endTime = d.getTime() + (waitTime * 60000); // convert back to milliseconds from minutes<br> return endTime;<br> <br>} // setMinutesTimer<br><br>function checkTimer(timer) {<br> var d = new Date();<br>// console.log('current time ' + d.getTime() + ' timer =' + timer);<br> if (d.getTime() > timer) {return true;} <br> else {return false;}<br><br>} // checkTimer<br><br><br>// Main Routine<br>function periodicActivity()<br>{<br> if (checkTimer(weatherTimer)) {getWeather(); weatherTimer = setMinutesTimer(240);} // every 4 hours<br> growLights();<br> tempControl();<br> checkECDoser();<br> waterEC();<br> if (checkTimer(waterLeverTimer)) {waterCirculation(); waterLeverTimer = setSecondsTimer(1);}<br> if (checkTimer(lcdDisplayTimer)) {lcdDisplay(); lcdDisplayTimer = setSecondsTimer(1);}<br> if (checkTimer(logTimer)) {sendToCloud(); logTimer = setMinutesTimer(1);}<br> setTimeout(periodicActivity,500); //call the indicated function after 1 second (1000 milliseconds)<br>}<br><br><br>Sensor reading
EC Sensor
// #EC Sensor <br><br>var ecSensor = new mraa.Aio(1);<br>var EC_reading = 0;<br>var ecDoser = new mraa.Gpio(6); <br>ecDoser.dir(mraa.DIR_OUT); //set the gpio direction to output<br>var ecDoserState = 0;<br>var ecDoserTimer = 0;<br>var ecDoserActivate = false;<br>var ecSampleTimer = 0;<br>var EC_DOSER_INTERVAL = 2; // seconds to run doser<br>var EC_SAMPLE_INTERVAL = 1; // minutes to wait before using EC reading to determine to dose<br>var EC_LIMIT = 1500; // dose when below this value minus EC_Band until it reaches this level<br>var EC_BAND = 200;<br>var EC_MS = 0; // EC micro/S<br><br><br>function waterEC() //Read Water ED<br>{<br> EC_reading = ecSensor.read(); // read the analog input voltage<br> // 0 to 1024 = 0 to 5v<br> // 204 micro/S per volt<br> EC_MS = (EC_reading * 4.88).toFixed(); // 5000 micro/S / 1024 = 4.88<br> if (EC_MS < (EC_LIMIT - EC_BAND)) { // outside of acceptible range<br> if (checkTimer(ecSampleTimer)) { // time to re-dose<br> ecSampleTimer = 0;<br> // console.log('--ecDoserState ' + ecDoserState);<br> if (ecDoserState != 1) { // if doser not ON then turn it ON<br> ecDoserActivate = true; <br> ecSampleTimer = setMinutesTimer(EC_SAMPLE_INTERVAL); // reset time until next sample - dose<br> console.log('dose for EC');<br> }<br> }<br>// console.log('lower than ' + (EC_LIMIT - EC_BAND));<br> }<br>// console.log('ecSampleTimer ' + ecSampleTimer);<br>// console.log('EC = ' + EC_MS);<br><br>} // waterEC()<br><br>function checkECDoser()<br>{ <br> if (ecDoserState == 0 && ecDoserActivate == true) // if not already on and needs to be on<br> {<br> ecDoserTimer = setSecondsTimer(EC_DOSER_INTERVAL); <br> ecDoserState = 1;<br> ecDoser.write(ecDoserState); <br> console.log('EC Doser is ' + ecDoserState + ' for ' + EC_DOSER_INTERVAL + ' seconds');<br> }<br> if (checkTimer(ecDoserTimer)) { // timer went off<br> ecDoserActivate = false;<br> ecDoserState = 0; // turn doser off <br> ecDoser.write(ecDoserState); <br>// console.log('EC Doser Timer Fired');<br> }<br>// console.log('ecDoserTimer ' + ecDoserTimer);<br>} // checkECDoser<br>Temperature
// Temperature<br>var tempSensor = new groveSensor.GroveTemp(3);<br>var tempBase = 23; // goal temperature<br>var tempTheshold = 25; // try to cool down<br>var tempAlarm = 27; // too hot sound alarm<br>var louverOpened = 160;<br>var louverClosed = 0;<br>var tempValue = 0;<br><br>function tempControl()<br>{<br> // when temp to high; turn on fans, open louvers<br> // if temp above theshold, stay on until lowered to base temp<br> // turn on buzzer at alarm temp<br> tempValue = tempSensor.value();<br>// console.log('temp is=' + tempValue);<br> if (tempValue > tempTheshold) {<br> fanCoolingState = 1;<br> servo.setAngle(louverOpened);<br> // console.log('temp hot');<br> } else if (tempValue <= tempBase) {<br> fanCoolingState = 0;<br> servo.setAngle(louverClosed);<br> // console.log('temp normal');<br> }<br> fanCooling.write(fanCoolingState);<br> <br> <br> if (tempValue >= tempAlarm) {<br> alarmState = alarmState ? 0:1;<br> alarm.write(alarmState);<br> } else {<br> alarm.write(0);<br> alarmState = 0;<br> }<br> // console.log('alarm is=' + alarmState);<br><br>} // tempControl()<br>Water Level Sensor
var waterSensor = require('jsupm_grovewater');<br>var waterLevel = new waterSensor.GroveWater(2);<br>var waterLeverTimer = 0;<br>var waterLevelValue = 0;<br>Light Level Sensor
var digitalLightSensor = require("jsupm_tsl2561");<br>var lightSensor = new digitalLightSensor.TSL2561();<br>var lightLevel = 0;<br>var lightLowCnt = 0;<br>var lightTimeRemaining = 960; // minutes in 16 hours<br>var lightDay = 1440; // minutes in 24 hour day<br>var lightsState = 0;<br>Controls and Control Logic
Circulation Pump
var circulationPump = new mraa.Gpio(4); <br>circulationPump.dir(mraa.DIR_OUT); //set the gpio direction to output<br>var circulationPumpState = 0;<br>var circulationPumpTimer = 0;<br>var CIRCULATION_PUMP_TIME_ON = 1; // pump time on<br>var CIRCULATION_PUMP_TIME_OFF = 1; // pump time off<br><br><br>function waterCirculation()<br>{<br> waterLevelValue = waterLevel.isWet();<br> if (waterLevelValue == true)<br> {<br> if (checkTimer(circulationPumpTimer)) {<br> if (circulationPumpState == 1) {<br> circulationPumpState = 0;<br> circulationPumpTimer = setMinutesTimer(CIRCULATION_PUMP_TIME_OFF);<br> } else {<br> circulationPumpState = 1;<br> circulationPumpTimer = setMinutesTimer(CIRCULATION_PUMP_TIME_ON);<br> }<br> circulationPump.write(circulationPumpState);<br> }<br> } else {<br> console.log('low water');<br> circulationPumpTimer = 0;<br> circulationPumpState = 0;<br> circulationPump.write(circulationPumpState);<br> }<br>// console.log('pump = ' + circulationPumpState);<br><br>} // waterCirculation<br>Servo Controller (for louvers)
//Instantiate Servo module on digital port 5<br>var servo = new servoModule.Servo(5);<br>servo.setMinPulseWidth(600);<br>servo.setMaxPulseWidth(2200);<br>
Fan Controller
var fanCooling = new mraa.Gpio(7); <br>fanCooling.dir(mraa.DIR_OUT); //set the gpio direction to output<br>var fanCoolingState = 0;<br>
Temperature Logic
function tempControl()<br>{<br> // when temp to high; turn on fans, open louvers<br> // if temp above theshold, stay on until lowered to base temp<br> // turn on buzzer at alarm temp<br> tempValue = tempSensor.value();<br>// console.log('temp is=' + tempValue);<br> if (tempValue > tempTheshold) {<br> fanCoolingState = 1;<br> servo.setAngle(louverOpened);<br> // console.log('temp hot');<br> } else if (tempValue <= tempBase) {<br> fanCoolingState = 0;<br> servo.setAngle(louverClosed);<br> // console.log('temp normal');<br> }<br> fanCooling.write(fanCoolingState);<br> <br> <br> if (tempValue >= tempAlarm) {<br> alarmState = alarmState ? 0:1;<br> alarm.write(alarmState);<br> } else {<br> alarm.write(0);<br> alarmState = 0;<br> }<br> // console.log('alarm is=' + alarmState);<br><br>} // tempControl()<br><br>Grow Lights
function growLights() // called every minute<br>{ <br> lightLevel = lightSensor.getLux();<br> if (lightLevel < 100 && lightTimeRemaining > 0) {<br> if (lightLowCnt < 2) {lightLowCnt++;} else {lightsState = 1; lightLowCnt = 0;}<br> } else {<br> lightsState = 0;<br> lightLowCnt = 0;<br> }<br> lights.write(lightsState);<br> lightTimeRemaining--; <br> lightDay--;<br> if (lightDay < 1) {lightDay = 1440; lightRemaining = 640;} // new day 24 hr day with 16 hours of light<br> if (lightLowCnt > 0) console.log('lightLow: ' + lightLowCnt); <br> console.log('LightLevel: ' + lightLevel);<br>} // end growLights<br>LCD Output
function lcdDisplay()<br>{<br> var lums = 0;<br> myLcd.clear();<br> myLcd.setCursor(0,0);<br> myLcd.write('Cond: ' + localWeather);<br> <br> myLcd.setCursor(1,0);<br> myLcd.write('EC:' + EC_MS);<br> <br> myLcd.setCursor(1,8);<br> if (lightLevel < 100) {lums = 'L';} else if (lightLevel < 130) {lums = 'M';} else {lums = 'H';}<br> myLcd.write('L:' + lums);<br> <br> myLcd.setCursor(1,12); <br> myLcd.write('T:' + tempSensor.value());<br>} // lcdDisplay<br><br>Publishing to the cloud
// Define your sensors for cloud publish<br>var data = [{<br> sensorName : "light",<br> sensorType: "light.v1.0"<br>},{<br> sensorName : "temperature", // air temp<br> sensorType: "temperature.v1.0"<br>}];<br><br>//Run Once to Init/Register sensors<br>data.forEach(function(item) {<br> registerNewSensor(item.sensorName, item.sensorType, function () { <br> });<br>});<br><br><br><br>function registerNewSensor(name, type, callback){<br> var msg = JSON.stringify({<br> n: name,<br> t: type<br> });<br><br> var sentMsg = new Buffer(msg);<br> console.log("Registering sensor: " + sentMsg);<br> client.send(sentMsg, 0, sentMsg.length, options.port, options.host, callback);<br>};<br><br><br>function sendObservation(name, value, on){<br> var msg = JSON.stringify({<br> n: name,<br> v: value,<br> on: on<br> });<br><br> var sentMsg = new Buffer(msg);<br> console.log("Sending observation: " + sentMsg);<br> client.send(sentMsg, 0, sentMsg.length, options.port, options.host);<br> <br>};<br><br><br>function sendToCloud(){<br> sendObservation("light", lightLevel, new Date().getTime());<br> sendObservation("temperature", tempValue, new Date().getTime());<br>} //sendToCloud<br><br>Fetching weather observations
var localWeather = 'Waiting';<br>var url = 'http://api.wunderground.com/api/df5bd75178df2c09/conditions/q/MA/Boston.json';<br>var weatherTimer = 1; // wait 1 minute before first call<br><br>function getWeather()<br>{<br> request({<br> url: url,<br> json: false<br> }, function (error, response, body) {<br> if (!error && response.statusCode === 200) {<br> var weatherReport = response.body;<br> localWeather = weatherReport.substr(weatherReport.indexOf('"weather":"') + 11,10);<br> }<br> });<br>} // getWeather<br><br>Step 4: Intel IoT Analytics Dashboard
Using Intel's IoT Analytics Dashboard
There are some great tutorials on getting set up on the dashboard here on instructables. I found Intel-IoT-Analytics-Dashboard by 10DotMatrix very helpful. Follow the steps outined there to get your account set up.
Once you get your account set up as described in the instructable by 10DotMatrix you can define the rules for notification and controls.
Building Rules in Intel's IoT Analytics Dashboard
- Go to the "Rules" menu item in the left hand nav
- My Rules Page
- Click the "Add a Rule" button
- My Rules - Detail Page
- Give your rule a name, select a priority and pick the type of action to take:
- Email - sends an email
- HTTP Endpoint - Call a webservice of your choice
- Actuation - This will integrate with your Edison to trigger an action you can code to
- My Rules - Devices Page
- Pick the device/devices you want to monitor
- My Rules - Conditions Page
- Monitor Measured - Select the control from the list of registered controls that you want to construct your rule against.
- Trigger When - Pick your trigger type
- Pick your operation type: equal to, greater than, etc...
- Enter your test value
Step 5: The Results
We are happy to announce we won 3rd place in the Intel IoT Hackathon - Boston!!!
A fun event and it was amazing to see all the great projects that came out of the event.
