Intel Edison I.R. Break Beam Sensor
3,731
11
Posted in TechnologyArduino
Introduction: Intel Edison I.R. Break Beam Sensor
About: lost my arm at 18, now I'm hacking stuff for disabled people (or animals)
Intel Edison Arduino I.R. Break Beam Sensor
Step 1: Parts
Intel Edison Arduino https://www.adafruit.com/products/2180
I.R. sensor https://www.adafruit.com/products/157
I.R. L.E.D. https://www.adafruit.com/products/387
I used the I.R. break beam sensor ( https://www.adafruit.com/products/2168), but you can recycle any broken device that uses an I.R. remote, as long as the I.R. L.E.D. and sensor aren't what's broken.
Step 2: Assembly
Wire it up like the picture above. You can add an external L.E.D. , I recommend pin 12, it wouldn't blink an external on pin 13, for me, but the on board L.E.D. did.
Step 3: Download the Code Below
IR Breakbeam sensor demo!
#define LEDPIN 12
// Pin 13: Arduino has an LED connected on pin 13
// Pin 11: Teensy 2.0 has the LED on pin 11
// Pin 6: Teensy++ 2.0 has the LED on pin 6
// Pin 13: Teensy 3.0 has the LED on pin 13
#define SENSORPIN 4
// variables will change:
int sensorState = 0, lastState=0;
// variable for reading the pushbutton status
void setup()
pinMode(LEDPIN, OUTPUT); // initialize the LED pin as an output:
pinMode(SENSORPIN, INPUT); // initialize the sensor pin as an input:
digitalWrite(SENSORPIN, HIGH); // turn on the pullup
Serial.begin(9600);
void loop()
// read the state of the pushbutton value:
sensorState = digitalRead(SENSORPIN);
// check if the sensor beam is broken
// if it is, the sensorState is LOW:
if (sensorState == LOW) {
digitalWrite(LEDPIN, HIGH); // turn LED on:
else {
digitalWrite(LEDPIN, LOW); // turn LED off:
if (sensorState && !lastState) {
Serial.println("Unbroken");
if (!sensorState && lastState) {
Serial.println("Broken");
lastState = sensorState;
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    do you know if it works with objects?
