Introduction: Intel Edison Fat Bike Tire Analyzer
Picture of Intel Edison Fat Bike Tire Analyzer
If you fat bike, you talk about tire pressure. The goal for many is to run as low a pressure as possible. I was curious just how much it differed at various pressures.
So with that, an Intel Edison and Flex sensor were used to look at PSI.
Step 1: Parts
Picture of Parts
I used the following parts:
Intel Edison Inventors Kit https://learn.sparkfun.com/tutorials/sparkfun-inv...
Flex Sensor: https://www.sparkfun.com/products/8606
Step 2: Connect
Picture of Connect
Wire up the flex sensor to A0 reading the postive leg, and + - to the flex sensor, with a resitor on the negative line.
Step 3: Install
Picture of Install
The flex sensor was stuck to the inside of a Maxxis Minion FBF 4.8" tire on an 82mm DT Swiss rim.
Step 4: Code
Picture of Code
I used this code to read the ADC: https://github.com/humberto-garza/SparkFunEdisonAD...
I modified it to record the readings and take PSI as an input which is just used to make the filename. It is attached as tireTest.py . The results are stored in a CSV.
I graphed them in excel, manual I know, but I don't plan on repeating this much.
Step 5: Results
Picture of Results
So what is the most interesting here too me, the tire gets the most flex at 6 PSI! Not 4 like I would have assumed, and as you would assume it is the most round at 10 PSI. I would have assumed 4 was the most flat, but interestingly while 4 PSI does not provide the widest footprint it does react the most. By that I mean the profile of the tire changes the most at 4 PSI.
By no means is this groundbreaking research, but anytime you make a widget it is fun!
S0dyP0p (author)2016-04-26
Nice measurement method, applied to answer a bike question. So many bike preferences gain almost holy-war status with nothing to back them up but what feels good and makes sense in one guy's head. SCIENCE RULES! Nice job.
Horrorzilla (author)2016-04-22
I like the idea but pretty sure it will not last long once it gets wet or dirty(which it will when riding off road). Also how is it powered - no mention of battery pack.
joe (author)Horrorzilla2016-04-22
Hey Horrorzilla - It is in no way meant to be waterproof, it was used on a dry test loop - my driveway. I used a USB battery pack, feel free to use any method you'd like to power it.
Cheers,
-Joe
About This Instructable
1,505views
5favorites
Bio: I like to tinker with just about anything, sometimes it works out in the end. Have fun looking at the projects, try tearing something open ... More »
More by joe:Intel Edison Garage Monitor and Alert SystemIntel Edison Fat Bike Tire AnalyzerIntel Galileo Garage Monitor
Add instructable to:
