3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Intelligent Solar Garden Light - Part 1
I bought a solar powered garden light. The solar panel charges the batteries and when it gets dark the lights (3x LEDs) turn on until it either gets lights again or the batteries run out.
It has a small amount of intelligence (turns on when dark off when light) but not enough! Time for some upgrades. :D
First, the batteries. The control box houses the batteries, which are three Ni-MH AA cells. They are 600mAh. (That's not a typo - six hundred). I swapped them out for three 1500mAh Ni-MH cells that I don't use anymore (because they are only 1500mAh).
Then I reverse engineered the circuit diagram for the electronics (nothing special there, two transistors, two resistors a switch and a diode).
I have a few ideas for sensors and transducers I want to add to the light, but I'll start by adding a microcontroller. Step forward the Arduino Wee made by SparkFun Electronics.
Step 1Existing Circuit Diagram
When light is falling on the solar cell, transistor Q1 is turned on and connects the base of transistor Q2 to ground. This isolates the output of Q2 keeping the LED spotlights turned off. When it gets dark, Q1 is turned off, leaving the emitter isolated (floating). Assuming SW1 is turned on, the base of Q2 will be high due to R2. This will turn Q2 on and connect the emitter to ground. This completes the circuit for the LED spotlights and they turn on.
6 comments
Mar 5, 2011. 11:21 AMalphaman1101 says:
You should probably use int for memory friendly..
Nov 13, 2008. 8:58 PMax89 says:
What is the cost of this? Does this only turn on the lights slowly at dusk? To be honest, doesn't seem worth the bother because the cool factor would be gone after seeing it in action one or two times.
Nov 13, 2008. 9:15 PMax89 says:
Okay, I found part 2 which added PIR. Does it significantly extend the battery life to give light for longer? Can't you add the PIR without the microcontroller? but that might reduce the geek cool factor though :(...
Nov 29, 2011. 4:12 PMax89 says:
...excluding the battery upgrade, which is definitely a good one.
Nov 10, 2008. 3:36 PMwierd idiot says:
nice work.
Nov 8, 2008. 6:32 PMsdallesasse says:
Too cool! Currently learning about this type of subject in school this semester.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:zzpza(All Alone in the Night)
I enjoy cycling and photography, and especially photography whilst cycling. :)
