Introduction: Intelligent Watering System With Arduino...
In this instructable i wanted to share my automatic irrigation system using arduino, soil humidity sensor and a simple aquarium valve attached to a servo... Humidity sensor takes constant readings of the soil moisture and transfers to Arduino which controls a mini servo attached to a tiny valve. you can tell the system amount of moisture needed simply turning the potentiometer... then the system opens and closes the water valve if the soil is below your specified level of moisture...
Parts needed:
- Soil humidity sensor ( dealextreme $3)
- Arduino of any kind (dealextreme $10)
- mini servo of any kind ( 9gm ~$5)
- aquarium valve
- 10K potentiometer
- water pipe (thin aquarium type)
First dip the fork of the humidity sensor to soil completely... connect sensor to A0 and 10K pot to A1 pins of Arduino. connect servo to D9 pin. power up the system with anything you like... (Wall adapter or battery )... Upload the sketch to arduino, adjust the pot and there you go... you can adjust the level of watering needed anytime by the potentiometer... thats all... You can put the system in a small waterproof project box of any kind... you can make a battery operated handheld system and add a16x2 lcd display to show moisture and watering status... please dont hesitate to contact me for any help and don't forget to vote for me if you like it... :) My other projects are on my web site... http://borsaci06.com
Here is the program, copy and paste it to Arduino IDE and upload:
/* Dincer Hepguler 2013
* http://borsaci06.com
* Read analog values from humidity sensor over the serial port
* Command a servo controlled watering system
const int numReadings = 20; //number of readings for smoothing
int readings[numReadings]; // the readings from the analog input
int index = 0; // the index of the current reading
int total = 0; // the running total
//int val = 0; // the average
#include
Servo myservo; //create servo object to control a servo
int sensorPin = A0; //humidity sensor at A0 (analog0)
int pos = 90; //variable to store servo position and set servo to center
int thresholdPin = A1; //threshold pot at A1
int val = analogRead(sensorPin);
int threshold = analogRead(thresholdPin);
void setup() {
Serial.begin(9600);
myservo.attach(9); // attaches the servo on pin 9
// initialize all the readings to 0:
for (int thisReading = 0; thisReading < numReadings; thisReading++)
readings[thisReading] = 0;
void loop() {
// subtract the last reading:
total= total - readings[index];
// read from the sensor:
readings[index] = analogRead(sensorPin);
// add the reading to the total:
total= total + readings[index];
// advance to the next position in the array:
index = index + 1;
// if we're at the end of the array...
if (index >= numReadings)
// ...wrap around to the beginning:
index = 0;
val = total / numReadings; // calculate the average
if ( val > threshold) { pos = 180; } //open valve if dry
else { pos = 60 ;} //keep valve closed otherwise
myservo.write(pos); // sets the servo position according to the scaled value
delay(15); // waits for the servo to get there
Serial.print(threshold);
Serial.print(" ");
Serial.print(val);
Serial.print(" ");
Serial.println(pos);
delay(10); // delay in between reads for stability
NOTE: I couldn't manage to add include statement, it dissappears during copy and paste... so don't forget to add an #include servo library...
Parts needed:
- aquarium valve
- 10K potentiometer
#include
void setup() {
Serial.begin(9600);
void loop() {
index = index + 1;
index = 0;
Serial.print(" ");
Serial.print(val);
Serial.print(" ");
