Interactive Arduino Powered Coffee Table
 by DanNixon
Contest WinnerFeatured
One quick fore note: this is my first Instructable and my first large Arduino project, so if you see any stupid errors or have an idea of how things could be done better, then please let me know.
Now that that's out of the way I'll begin, I started designing this around September last year as my A2 Product Design project and thought that it might make a good Instructable once it was finished.
The design of the table aspect was inspired mainly from another table I had seen with a similar arched shape but with a flat top, and the electronics were mainly inspire from this coffee table, although I wanted something easier so I used a 16x16 single colour matrix and two LCD displays on my table, there is also an audio amplifier and Bluetooth receiver for playing music through the table.
So that's all there really is to say, most of the things that are part of the finished product were thought up along the way, but here are some of my original designs anyway.
Here is a video of the table in action, it also helps to explain the functionality of the electronics better than I do later on in the Instructable:
Step 1: Main Arch Assembly - Part 1
For making my table I had full access to the CNC machines at school so parts could be cut to the correct sizes easily, this was mainly done on a Boxford CNC router which could cut sheets of MDF up to 1200x600mm, I'll include the 2Ddesign drawings I used for the machine, but so far I haven't seen anyone else use the same software.
However there is no reason this couldn't be done using a hand router, so I'll include some imaged of all the parts and their sizes as well.
The first set of parts was the MDF panels to make up the main arch for the table, this was two arched panels with slots routed into them and smaller panels that fir into the slots between the two panels.
After the parts had finished being machined, they require a quick sand down to remove any loose MDF fibre then they are ready to be assembled and glued, I used standard PVA adhesive and clamped the two arched panels around the smaller panels while the glue set, but you could get similar results by using some wood screws in the joints to keep them secure while the glue sets.
If you do want to adapt the design of the table, the main thing to keep in mind is the space required for all of the electronics and how they will be mounted internally, always be sure to leave more space than what you think you will need.
The design I had chosen contained 5 internal sections, of which 4 of them would hold MDF panels, each of which held some of the electronics (I'll call these "blades" because it sounds cool).
Also I have included a ZIP archive of all the drawings I used with CNC machines in making the table on this step.
AntzyP says: Apr 22, 2012. 9:53 AM
cool... i loved the song and album display!
Also, the visualization light on the ceiling was awesome...
Christinasadler says: Apr 21, 2012. 3:43 AM
I can see this becoming the 2012 A-Lister must have addition to the penthouse furnishings.
Lindie says: Apr 20, 2012. 6:39 AM
Wow! Very cool!
dragonz2444 says: Apr 18, 2012. 8:52 AM
Video when you have the chance, tables look great! Does it just tweet and play music? If so, still awesome! Now all you need is some sound reactive LEDs for the music! Maybe filling in the empty area around the electronics in the middle with an Aurora http://www.instructables.com/id/Aurora-18x18
DanNixon (author) in reply to dragonz2444Apr 18, 2012. 9:12 AM
I should get a video done later today that helps to explain the functionality of the table a little better.
The table has two "modes", news and media, in news the LED matrix is blank and an RSS feed is shown on the green LCD and weather forecast on the blue LCD, in media mode the LED matrix reacts to the music, the blue LCD shows the current song (via Last.fm) and the green LCD is blank.
I hope to explain this better in a video, but it is difficult as I cannot take the table home as it has to be marked for my A level in Product Design and the Ethernet shield does not support networks that use a proxy server.
Foxtrot70 says: Apr 18, 2012. 6:57 AM
Dan - What was the final cost of the project? Excellent work by the way!
DanNixon (author) in reply to Foxtrot70Apr 18, 2012. 9:08 AM
Thanks, total cost was around £190, around £60 for the electronics, £75 for the glass surface and £55 for the rest of the materials, plywood etc.
ZANIESXD says: Apr 17, 2012. 12:43 PM
it looks like you have a dead led on your matrix in the test video
DanNixon (author) in reply to ZANIESXDApr 17, 2012. 12:48 PM
Yeah, there were about three that never lit and one that flickered occasionally, I'm not sure if it was because I burned them when soldering or they were just bad LEDs (I checked the polarity and that was fine).
This did really annoy me, but I couldn't see any easy way of fixing it.
fungus amungus says: Apr 17, 2012. 10:11 AM
Nice. When you get a video done you should add it to the intro
DanNixon (author) in reply to fungus amungusApr 17, 2012. 11:14 AM
Thanks, and yeah I'll put it in the intro.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
