3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Interactive Multitouch Display
Step 3Led rails
led rails
The leds are mounted in extruded aluminum c-channel, pressed into holes. The channel serves to hold the leds in place as well as providing a baffle to direct the light into the edge of the acrylic. Additional spacer blocks cut from acrylic keep the panel from sliding around and pushing the leds out of their holes.
8 comments
Feb 24, 2011. 1:02 PMpsalanoa says:
how do you press the holes into theextruded aluminum c-channel?
Apr 20, 2010. 5:12 AMdanny9893 says:
Hey just a question but do the LEDs go all the way around the board?
Apr 9, 2009. 8:16 AMautomata says:
How far apart are the LED holes in the aluminum frame? Do both vertical bars and horizontal have the same spacing or is it different. I am assuming the IR's make a grid and the grid should have equal units between each IR. Thanks in advance
Mar 28, 2010. 11:03 AMTreknology says:
 It's not about creating a grid, it's about creating a uniform distribution of IR throughout the acrylic sheet, in the same way that you want uniform distribution of visible light in an LCD panel.
"Frustrated" Infra-Red remains trapped between the two outer surfaces of the acrylic, and the presence of a finger causes an image to be produced underneath which I'm guessing in future steps will be detected by IR cameras.
I just don't understand why TWO sheets were used.
Nov 9, 2009. 9:12 PMRjessick says:
Hey, I commented on an earlier step... Just a thought. Adding like two times the amount of LED's would really improve how well the table senses your finger touches.
Apr 9, 2008. 10:36 PMZero-Vision says:
Ok, so I'm working on a modified version of what you did here. A couple questions reguarding LED, and rail placement. 1) What degree of spread were your led's. I'm considering using ones with 40 degree angle. The assumption being wider spread, less led's needed. You also used 950nm range leds. Could I use slightly lower range ones, since cams tend to be more sensetive to closer range Light waves? say 800nm or so?
Jul 4, 2007. 4:44 PMmustafa.alrefaee says:
what are the spacer blocks and where exactly to do you place them... are they only placed on the edges or between every led?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
63
Author:turkey tek
thanksgiving! ...and bringing technology to this traditional celebration of excess.
