3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Interactive Multitouch Display
Step 4Led mounting and wiring
led mounting and wiring
I used 88 infrared leds I ordered surplus online. Their maximum output was 10mW @ 940 nm. Each led needed 100mA at 1.45V so i wired sets of 8 in series along with a 5 ohm resistor. I wired these sets in paralell across the 12V rail of an old computer power supply I had lying around. Since the total current draw is over an amp, you can't get by with a wall wart.
Pour yourself a glass of whiskey and fire up the soldering iron...it will take a while to wire up 88 leds.
10 comments
Mar 30, 2010. 7:37 AMUniBot says:
Well if you use the 3v output from your standard ATX power supply, you can hook up in parallel N modules of 2 LED's in series (MODULES in parallel, LEDS in series), being theese in a total power consumption of 2.8v... 3v will do, since (I think) that's within the LED's electric tolerance. Then you hook up (as i said) N modules, with this I mean until you complete the average total amperage of a normal ATX power supply (commonly 19amps), with that you can plug as many LED's as you want (as long as theyre within your power supply capabilities).
Jul 10, 2010. 1:05 PMshinjiyuubix says:
Without any resistors? Can you draw here a schematic? Thx
Sep 26, 2010. 8:15 PMUniBot says:
Im sorry for the delay, but heres a quick schematic. The thick lines are the 3v power output from the ATX power supply, (positive and negative respectively). the rectangles are (supposedly) LEDs hooked up in series of two LEDs drawing a total voltage of 3 volts (YAY! thats exactly the same voltage than the ATX! xD), thats what we'll call a "module". If we assume that each LED draws 50 Ma (milliamperes), then each "module" will draw that amount from the power supply, if you hook up more modules to the power output of the ATX power suply in PARALLEL you can keep up until you fill the 19,000 Ma (19Amps [depending on your power supply capacity]) of total capacity... that's a HELL LOTTA LEDS MAN!
PS: im sorry for the lame paint-made schematic.
PPS:I know, I made a short story long. Who cares? xD
Oct 4, 2010. 3:02 AMshinjiyuubix says:
Ok ok.... thx
Mar 21, 2010. 2:13 PMcrazydog75 says:
Ok so i have a <24> x ^18v piece of acrylic/plastic. how many LEDs do i need, what type of power supply, resistors, and other stuff do i need? i can get a lot of 50 ir leds on ebay for $5 supposedly
May 4, 2010. 11:41 AMooda55 says:
Someone else mentioned that the LED's should be about 1.5 inches apart
and from experience IR LED's usualy work best at about 1.5v and i think they are about 50mA
so if you linked them all up in paralell you would be looking at a 1.5v 2500mA (2.5A) supply to power all 50 LED's
Sep 22, 2009. 4:02 PMautomata says:
Hopefully not a completely stupid question… but I need some clarity on the power supply hookup I have all my LED's soldered with resistors on the rails. I have an old power supply from a Mac G4 22 pin P1 connector and a 4 pin P4 connector The yellow wire is listed as 12+ volt and the black wires are ground Can anyone offer any guidance on how to hook up the wires to the LED array? I am hoping to not fry the LED's right off. Thanks in Advance
Aug 23, 2007. 5:02 PMksjlkdjlddj says:
where did you buy your leds? I have no idea where to get them without being ripped off . . . great guide by the way. thank you
Sep 8, 2007. 9:49 PMbrad says:
lck-led.com has a good selection on the cheap, but their inventory varies widely. Also try eBay.
Apr 27, 2009. 5:56 PMbrad says:
Ignore that loser. He doesn't know where to get IR LEDs in this modern day.
http://www.dealextreme.com/details.dx/sku.2399
$2.93 for 20 (as of the time of this posting)
Jun 30, 2009. 8:53 AMalexander3133 says:
What is the wavelength of the IR led you stated? Thanks.
Jun 30, 2009. 10:59 AMbrad says:
The only one I saw tested read 808nm. There is just a tiny bit of red visible when running.
May 31, 2009. 6:24 PMHypernoob says:
where do you solder the resistor? it's not seen in any of the pictures. Just curious as I might be building one of this myself. and because you are using aluminum the place where you place your resistor is important at it might cause a short circuit am i right?
Jul 31, 2007. 1:51 AMmickshake says:
i ended up frying 16 LEDs when i connected the - lines to the ground on the power supply. They seemed to work fine when i ran each - wire to the ground directly.. ill try to draw the schematic i have 2 groups of 8 leds on one strip the set on the left is +- +- +- +- +- +- +- +- the set on the right is -+ -+-+-+-+-+-+-+-+ so they both meet in the middle on a - i ran each series to the ground/power separately and everything worked fine. when i tried to eliminate one of the ground wires and join the 2 negatives it fried the LEDs. I don't have any resistors in the circuit because my LEDs are rated 1.4~1.5v (and because radioshack didn't have a single 5 ohm resistor), is that what caused the blown LEDs? did I just get lucky the first 2 or 3 times when testing each set with its on wires? or did joining that ground throw it off? It doesn't make sense.. the ground wires meet at the black wire anyway right? I wish I knew more about circuits.. thanks for all the help so far!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
63
Author:turkey tek
thanksgiving! ...and bringing technology to this traditional celebration of excess.
