Step 6Screen sandwich assembly
iImage Information
Once the frame, rails and acrylic are prepared you are ready for the final assembly. Clamp the layers together for easy drilling and bolt them in place. Once the sandwich is assembled, it is necessary to caulk along the edge of the aluminum in order to block any light that might spill out thru the crack. We want it all nicely ducting along the inside of the acrylic instead.
In order for the projector to display on the surface it is necessary to also introduce a diffuser (not shown here). A sheet of thin drafting paper was included in the sandwich supported by a second thin layer of plexiglass.
Has anyone tried mounting the projector under the table yet and setting the screen to rear projection?
I'd like to know if it works, would make for a neater and more portable install.
you can have the projector in the top corner near your screen and reflect it off a mirror at the bottom of your case. that works too
Also, I noticed you were having just a tad difficulty playing with those picture files. Is that a problem with the web cam used?
Please contact me on this. Id like to know more. about making my own.
pros:
-good visibility
-easy installation, it sticks to acryllic thanks to static electricity
cons:
-limited size availability. maximum size I know of: mercury format (110 x 77 cm)
-critical installation. if theres an air bubble between the acryllic and the paper, the IR refraction of the finger will turn too blurred and inaccurate.
-environment. the vegetal paper is EXTREMELY sensitive to changes in temerature and moisture, too much moisture... and the paper bends on itself, causing air bubbles where we dont want them.
