Interface LED Dot Matrix (8x8) With NodeMCU
2,342
24
Published
Introduction: Interface LED Dot Matrix (8x8) With NodeMCU
About: Work until you no longer have to introduce yourself.
Hello Makers,
I'm with another simple and cool Instructable.
In this Instructable we will learn how to Interface LED Dot Matrix (8x8) with NodeMCU.
So, let's begin.
Step 1: Things Needed
These are the required things to do this Instructables.
Hardware Requirement
  • LED Dot Matrix (8x8)
  • NodeMCU
  • Jumper wires / Connecting wires ( Optional )
  • BreadBoard
  • Micro USB Cable
Software Requirements
  • Arduino IDE ( with ESP8266 library installed )
Step 2: Description
An LED Dot Matrix or LED Display is a large, low-resolution form of dot-matrix display.
It is useful for both industrial and commercial purpose, to display information as well as for hobbyist human–machine interfaces.
It consists of a 2-D diode matrix with their cathodes joined in rows and their anodes joined in columns (or vice versa).
By controlling the flow of electricity through each row and column pair it is possible to control each LED individually.
Step 3: Circuit Wiring
The Dot Matrix has 5 pins i.e.,
VCC - To be connected to NodeMCU Vin.
GND - To be connected to Ground Pin (GND) of the NodeMCU.
Din - To be connected to Digital Pin D0 of the NodeMCU.
CS - To be connected to Digital Pin D1 of the NodeMCU.
CLK - To be connected to Digital Pin D2 of the NodeMCU.
Step 4: Library Setup
Before you get started with coding you need Arduino IDE.
To download Arduino IDE and for NodeMCU setup, you can check my previous instructable. And for this Instructable you need LedControl Matrix LIbrary, you can download it from the link below.
LED Control Library
Ok, let's begin with coding.
Step 5: Source Code
CODE :
#include <LedControl.h>
int DIN = 16; // D0
int CS =  5;  // D1
int CLK = 4;  // D2
LedControl lc=LedControl(DIN,CLK,CS,0);
void setup(){
	lc.shutdown(0,false);     //The MAX72XX is in power-saving mode on startup
	lc.setIntensity(0,15);     // Set the brightness to maximum value
	lc.clearDisplay(0);        // and clear the display
void loop() {
    byte a[8] = {0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xFF,0xFF};  // L
    byte b[8] = {0xFF,0xFF,0x18,0x18,0x18,0x18,0xFF,0xFF};     // I
    byte c[8] = {0x7F,0xFF,0xC0,0xDF,0xDF,0xC3,0x7F,0x3F};   // G
    byte d[8] = {0xC3,0xC3,0xC3,0xFF,0xFF,0xC3,0xC3,0xC3}; // H
    byte e[8] = {0xFF,0xFF,0x18,0x18,0x18,0x18,0x18,0x18};    // T
    byte f[8] = {0xC3,0xC3,0xC3,0xFF,0xFF,0xC3,0xC3,0xC3};  // H
    byte g[8] = {0x3C,0x7E,0xC3,0xC3,0xC3,0xC3,0x7E,0x3C}; // O
    byte h[8] = {0xC3,0xC3,0xC3,0xC3,0xC3,0xC3,0xFF,0xFF};  // U
    byte i[8] = {0x7F,0xFE,0xC0,0xFE,0x7F,0x03,0x7F,0xFE};     // S
    byte j[8] = {0xFF,0xFF,0xC0,0xF8,0xF8,0xC0,0xFF,0xFF};     // E
    printByte(a);
    delay(1000);
    printByte(b);
    delay(1000);
    printByte(c);
    delay(1000);
    printByte(d);
    delay(1000);
    printByte(e);
    delay(1000);
    printByte(f);
    delay(1000);
    printByte(g);
    delay(1000);
    printByte(h);
    delay(1000);
    printByte(i);
    delay(1000);
    printByte(j);
    delay(1000);
void printByte(byte character []){
  int i = 0;
  for(i=0;i<8;i++)
    lc.setRow(0,i,character[i]);
Download the code " LED_DotMatrix_NodeMCU.ino" attached below.
You can tinker with the code as you wish, or use it as it is.
Step 6: OUTPUT
That's all makers!
I hope you liked this. Stay Tuned for more Projects!
Thank You.
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
