Interface a rotary phone dial to an Arduino by guidomax
Featured
An old rotary phone can be used for a number of purposes in your Arduino projects - use it as a novel input device, or use the Arduino to interface a rotary phone to your computer.
This is a very basic guide describing how to interface the dial to an Arduino, and get the number dialed passed into a computer over the Arduino's serial link.
Step 1: Remove the dial from the phone
First step is to remove the dial unit from the phone. I'm using a GPO phone of some sort from the 1970s.
On this phone, the dial popped straight out - I just needed to give it a tug. If it doesn't, you may have to open up the phone and work out how to get it off.
There were five cables connected to the back of the dial unit. On my phone, these were regular spade connections, so I loosened the screws and pulled them out. If you want to re-assemble your phone, remember to record which color wire goes to which connection.
Step 2: Identify the switch
Once the dial is out, it should be relatively easy to see how the dial converts rotary movement into pulses. Try spinning the dial by hand and watching the movement on the back. You should see a switch making and breaking a circuit rapidly - so if you dial '9', the switch should engage nine times.
For those of you who may never have used a rotary dial before - remember that the dialing only happens when you let go the number and let it spool back .
I've documented how it works for my phone in the Notes of the photo below.
There's also a blurry video of the mechanism working.
Step 3: Make the circuit
Once you have found the switch that is being made and broken, you should be able to identify the connections by following the wires back to the connection terminals. In my case, the two sides of the switch are connected to the two leftmost terminals.
Hook up these terminals to some jumper wires, and get prototyping! The switch in my dial is always-on, and is broken for each pulse when dialling, so I used the very simple circuit below. Pin 2 will go HIGH for each pulse as the dial rotates.
When the phone isn't being dialed, the switch in the dial unit is closed (a so-called NORMALLY CLOSED switch, for obvious reasons) so the circuit connects pin 2 to ground (which to the Arduino is LOW). This is because there is much less resistance through the 470 ohm resistor than the 10K resistor.
When the phone is being dialed, the switch opens and closes rapidly (for a 9, it will open and close again nine times, remember). When the switch is open, pin 2 is not connected to ground - instead it is connected to the 5V supply through a resistance of 10470 ohms. This is interpreted by the Arduino as a HIGH.
If your dial has a NORMALLY OPEN switch, then swapping the positions of the 10K resistor and the dial should do the trick.
Step 4: Develop the code
Now we need some code for the Arduino to count the pulses and send the total number per number dialed back through the serial port.
My code's below. As we're dealing with mechanicals here, yours may differ. Try playing about with the debounce constant and the 'how long do we wait before assuming dial has finished rotating' constant.
I've tried to comment it as neatly as I can. Hopefully it's pretty simple.
int needToPrint = 0;
int count;
int in = 2;
int lastState = LOW;
int trueState = LOW;
long lastStateChangeTime = 0;
int cleared = 0;
// constants
int dialHasFinishedRotatingAfterMs = 100;
int debounceDelay = 10;
void setup()
Serial.begin(9600);
pinMode(in, INPUT);
void loop()
int reading = digitalRead(in);
if ((millis() - lastStateChangeTime) > dialHasFinishedRotatingAfterMs) {
// the dial isn't being dialed, or has just finished being dialed.
if (needToPrint) {
// if it's only just finished being dialed, we need to send the number down the serial
// line and reset the count. We mod the count by 10 because '0' will send 10 pulses.
Serial.print(count % 10, DEC);
needToPrint = 0;
count = 0;
cleared = 0;
if (reading != lastState) {
lastStateChangeTime = millis();
if ((millis() - lastStateChangeTime) > debounceDelay) {
// debounce - this happens once it's stablized
if (reading != trueState) {
// this means that the switch has either just gone from closed->open or vice versa.
trueState = reading;
if (trueState == HIGH) {
// increment the count of pulses if it's gone high.
count++;
needToPrint = 1; // we'll need to print this number (once the dial has finished rotating)
lastState = reading;
Step 5: Check it works!
Check it works by opening up a serial window (I use screen on a unix machine, you may want to use Hyperterm or similar on Windows), and try dialing some numbers.
Make sure that the serial program is set to read from the USB->serial adaptor in your Arduino (check the Tools->Serial Port menu in the Arduino software if you forget what that is), and a baud rate of 9600 bps.
You should see the correct number pop up as it's dialed.
Step 6: Hook it into something useful!
I came up with a Quartz Composer file on my Mac to take the input and render it nicely to the screen. Once it's in the machine as serial data, you can do anything with it.
Waiting to hear your ideas!
I'll come up with a video of it 'in action' and printing the numbers to the screen as soon as I can get someone to hold the camera for me - wish I had three hands.
matsk says: Apr 24, 2013. 11:24 AM
Changes to the code to cover different rotary dials.
Serial.print(count - 1);         // Rotary dials that begins with zero and ends with 9
Serial.print("  ")
Serial.println(count % 10, DEC); // Rotary dials that begins with 1 and ends with zero
englishfire says: Jul 22, 2012. 8:33 AM
Hello, I just tried the code and it works. :)
My problem is this:
I'd like to enter a code via the telephone dial to open a door. If the code is correct then the door should open.
Can you help me??
Greetings from Germany Maik
FirebladeNL says: Jul 3, 2012. 12:51 PM
This setup and program works perfectly on the old Dutch PPT T65 rotary telephone, just hooked it up. Now to figure out how to play sound so when the right number is dialled, one will get a certain message (that's for a different hobby of mine, geocaching)
Thanks a bunch for these instructions, a great help!
philip42 says: Dec 6, 2011. 10:21 PM
Why is it necessary to disassemble the dial? Couldn't you read the pulses directly from the phone line (red and green wires). All it is is a sequence of open-close pulses from the mechanical dial.
TechDante says: Oct 8, 2011. 11:41 AM
had a problem with getting teh wrong output to the numbers (1 became 2 and so on) solved it by changeing the debounce to 20mille seconds and this did the trick
alexhb says: May 19, 2011. 1:12 PM
same setup here... makes for much easier programming ;)
Montrose says: Dec 27, 2010. 1:58 PM
I like the Skype idea. One could install the necessary computer inside of an ornate base with a flat screen monitor mounted behind the phone and what ever other antique details. It could be a very Steampunk video phone or perhaps use aluminum and go with a Machine Age phone. Oh for the time to explore all the options.
jtmcdole says: Dec 14, 2010. 7:39 AM
Idea:
-use as a dieselpunk safe/door lock.
-Interface dialer, handset, and google voice to receive and make calls from a physical phone.
TechDante says: Jul 10, 2010. 3:49 PM
hello i am interested in electronics for my end of year project, but i am just starting out properly into electronics and programing and saw the arduino as a good starting point. could you recomend any reading material i could look into (already have the Arduino Notebook from their website and the make Magazine getting started with Arduino)
Irregular Shed says: Dec 30, 2009. 3:29 AM
 On the dial I've pulled out to use there's another switch that opens when the dial is turned to a number and closes when it has finished pulsing. I'm planning on using that instead of waiting longer because I'm also going to be having a keypad matrix to scan and an LCD to power!
kissiltur says: Oct 20, 2009. 8:48 AM
splendid, splendid. Haven't thought about pulse dialling since I stopped working for a telecomms equipment company, lo, these many moos ago.
I had fun explaining to my four year old about how this phone works a bit differently from all the phones he sees in the house.
Father Christmas says: Oct 20, 2009. 4:29 PM
lol @ "many moos ago."
I too measure my time scale by bovine vocalization! haha
Aerospaced says: Oct 20, 2009. 5:24 AM
Hang on a bit, you said that if you dial 9 that it will tap out nine times on the switch. As I recall, when hand keying a phone, you add 1 to every number.
guidomax (author) says: Oct 20, 2009. 6:26 AM
Hi,
Thanks for the comment - an interesting topic. It appears that the pulse dialing regime varies by geographic area, however in the UK (where this telephone is from) and North America, the number of pulses corresponds directly to the number dialed. This is certainly what happens for my telephone - obviously people in other countries may have to alter the source code to account for their particular phone.
Cheers :)
From en.wikipedia.org/wiki/Pulse_dialing :
In most countries one click is used for the digit 1, two clicks for 2, and so on, with ten clicks for the digit 0; this makes the code unary, excepting the digit 0. Two exceptions to this are New Zealand, with ten clicks for 0, nine clicks for 1, and so on, and Sweden, with one click for 0, two clicks for 1, and so on.
PS118 says: Jul 20, 2009. 1:54 PM
One word: Skype! ;)
guidomax (author) says: Jul 20, 2009. 2:06 PM
It's a plan - that'd be pretty cool!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
