Interfacing 20x4 LCD With Arduino
Published
Introduction: Interfacing 20x4 LCD With Arduino
About: An electronics enthusiast... #Complexity simplified
A liquid-crystal display (LCD) is a flat panel display, electronic visual display, or video display that uses the light modulating properties of liquid crystals. Liquid crystals do not emit light directly.
Here, in this i'ble we're going to use a monochromatic 20x4 alphanumeric LCD. 20x4 means that 20 characters can be displayed in each of the 4 rows of the 20x4 LCD, thus a total of 80 characters can be displayed at any instance of time.
Step 1: Material Required
List of requirements is as follows:
1. Arduino/or any other clone
2. 20x4 LCD
3. Breadboard
4. 1k, 220R Resistors
5. Connecting wires
Step 2: LCD-Pinout
The LCD we are using has 16 pins. Description of each pin is as follows:
Pin No Symbol Level Description
1 VSS 0V Ground
2 VDD 5V Supply Voltage for logic
3 VO (Variable) Operating voltage for LCD
4 RS H/L H: DATA, L: Instruction code
5 R/W H/L H: Read(MPU?Module) L: Write(MPU?Module)
6 EH H->L Chip enable signal
7 DB0 H/L Data bus line
8 DB1 H/L Data bus line
9 DB2 H/L Data bus line
10 DB3 H/L Data bus line
11 DB4 H/L Data bus line
12 DB5 H/L Data bus line
13 DB6 H/L Data bus line
14 DB7 H/L Data bus line
15 A 5V LED +
16 K 0V LED-
Step 3: Schematic
1. Study the schematic carefully.
2. Place your LCD on the bread board.
3. Make connections as per the schematic.
4. Instead of the potentiometer, you can use a 1k resistor and connect Pin 3 of LCD to Vcc via the resistor.
5. Carefully check whether all the connections are tight and correct.
6. Power up your Arduino via USB and check whether the LCD lights up. If yes, proceed.
Step 4: Code
There are two options that you can follow, either you can build up your own code, if you know how to or you can use the example code from the built-in Arduino library "LiquidCrystal.h".
I have used the HelloWorld example from the library. You can find this example in Arduino IDE following the path: File->Examples->LiquidCrystal->HelloWorld.
Now connect the Arduino to any of the USB ports and upload the code.
Once the code is uploaded, you must be able to see "hello, world" printed on the LCD.
Step 5: That's All
2 People Made This Project!
  • Creative Misuse Contest
  • Oil Contest
    Oil Contest
  • Clocks Contest
    Clocks Contest
13 Discussions
Its work for me after I made the following changes:
void setup() {
delay(2000);// add to give some time to start the LCD
// set up the LCD's number of columns and rows:
lcd.begin(20, 4); //
// Print a message to the LCD.
lcd.print("line 1 8901234567890");
lcd.print("line 2 8901234567890");
lcd.print("line 3 8901234567890");
lcd.print("line 4 8901234567890");
You are posting this instruction for 20*4 since you have used 16*2 in your program??
This is a very good instructable as I have a need to test an 20x4 LCD display that was attached to a smart reprap board.
Thanks
Hi,
I am working with 4x20 LCD ...how to select 4 lines plz helpme... i dont have proper datasheet..
lcd.setCursor(x, y);
Set x as the charcter pos. And y for the line..
ebi86
2 years ago
hi dear
there is a problem. pin 3 can be connected to GND via a resistor; not to vcc
thanks
It can be done.
The pot acts as a voltage divider, if I connect Pin3 to Vcc via a resistor, it'll still work as the Pin3 will have a floating ground. Thus, it solves the purpose of voltage division.
ebi86
2 years ago
please write a sample code in bascom version thanks
Estimado, lo hice y no me funciona, el diagrama es exacto.
Hasta probé modificar el
lcd.begin(20, 4);
Alguien me dijo de modificar la librería, vos lo hiciste o te anduvo de primeras?.
Gracias.
Ya lo resolví, le saqué el potenciómetro y le puse una resistencia de 10k.
Saludos!.
I2C and serial versions of LCD does save pins but for beginners, I think this is better to use and understand.
