Introduction: Interfacing BMP180 Barometric Sensor With Mediatek Linkit One
Picture of Interfacing BMP180 Barometric Sensor With Mediatek Linkit One
In This Instructable ,You will be able To Interface BMP 180 with Linkit One Board.BMP180 is A Digital Barometric Pressure Sensor through which You will Be able To Measure Pressure, Altitude and Temperature.
Step 1: Requirements
Mediatek Linkit One Board
BMP 180 : Barometric Sensor
Jumper Wires
USB Cable For Board
Step 2: Connections
Picture of Connections
Vin : 3V3 On Board
GND : Gnd
SCL : SCL On Board
SDA. : SDA On Board
Step 3: Code,Compile and Run
Picture of Code,Compile and Run
Upload The Code, Import the header file attached above And You Can See The Output On The Serial Monitor Depending Upon The Environment Conditions.
Congratulations!!! You Have successfully Interfaced BMP 180 with LinkIt One Board!!
phyominthant (author)2016-04-11
This always showing 20meter. Altitude is not changing even i go from basement to level 10. Can u check again please?
ParthP23 (author)phyominthant2016-04-12
yaa Okay will Check It and Let u know soon
phyominthant (author)ParthP232016-08-01
Brother, have you found the working code?
About This Instructable
592views
6favorites
License:
More by ParthP23:Automated Revolving Door With Mediatek Linkit OneFlow Rate Measurement With Mediatek Linkit One BoardObstacle Avoiding Robot Using IR Module Interfaced  With Mediatek LinkIt One Board
Add instructable to:
