Introduction: Interfacing DHT Sensor With OLED & ArduinoUno
Picture of Interfacing DHT Sensor With OLED & ArduinoUno
Hello, Makers!!
In this Instructable, I'll show you how to Interface DHT sensor with OLED using the ArduinoUNO.
For example, growing plants require specific temperature and humidity to be maintained, in this instructable I'm going to show you how to make a device that measures the humidity data and temperature data and displays it on an OLED screen.
Step 1: Components Required
Picture of Components Required
Here is the list of components required to get started with the Instructable,
Hardware Components
  • Arduino Uno
  • DHT11
  • 0.96” SSD1306 OLED
  • Bread Board
  • Jumper Wires
  • Micro USB Cable
Software Components
  • Arduino IDE
Step 2: Description
Picture of Description
The DHT11 is a basic, ultra low-cost digital temperature and humidity sensor. It uses a capacitive humidity sensor and a thermistor to measure the surrounding air and spits out a digital signal on the data pin (no analog input pins needed). It's fairly simple to use but requires careful timing to grab data. The only real downside of this sensor is you can only get new data from it once every 2 seconds, so when using library, sensor readings can be up to 2 seconds old
Step 3: DHT11 Connection
Picture of DHT11 Connection
Wiring the DHT11 to the Arduino Uno is really easy, but the connections are different depending on which type you have either 3-pins or 4-pins.
The wiring connections are made as follows :
  • Pin 1 of the DHT11 goes into GND of the Arduino Uno.
  • Pin 2 of the DHT11 goes into +5V of the Arduino Uno.
  • Pin 3 of the DHT11 goes into Digital Pin 7 of the Arduino Uno.
Step 4: DHT Library Setup
DHT sensor can be easily coded with a library file called dhtlib. dhtlib, this library can be used for reading both values from DHT sensors. The DHT11 only returns integers (e.g. 20) and does not support negative values
The library file can be downloaded by following steps
1. Go to > Sketch
2. Include Library
3. Manage Library
4. Download dhtlib library file Or you can download the attached file below.
Step 5: OLED Connection
Picture of OLED Connection
Connection scheme:
  • CS pin of the OLED is connected to Digital Pin 8 of the ArduinoUNO.
  • DC of the OLED is connected to Digital Pin 9 of the ArduinoUNO.
  • Reset of the OLED is connected to Digital Pin 10 of the ArduinoUNO.
  • SDA of the OLED is connected to Digital Pin 11 of the ArduinoUNO.
  • SCK of the OLED is connected to Digital Pin 12 of the ArduinoUNO.
  • VDD of the OLED is connected to 5v of the ArduinoUNO.
  • GND of the OLED is connected to ground (GND) pin of the ArduinoUNO.
Step 6: OLED Library Setup
Picture of OLED Library Setup
OLED can be easily coded with a library file called Ug8lib. Ug8lib is a graphics library which supports many different monochrome displays.
1. Go to > Sketch
2. Include Library
3. Manage Library
4. Download U8g lib library file Or you can download from the link attached below.
"U8glib_Arduino"
Step 7: CODE
<p>#include <U8glib.h>
#include <dht.h>
dht DHT;
#define DHT11_PIN 7
U8GLIB_SSD1306_128X64
u8g(12, 11, 8, 9, 10); // arduino HW SPI com: SCK = 12,SDA = 11,CS = 8,DC = 9,RES = 10
void setup() {
/* nothing to do here */
void loop()
   u8g.firstPage();
   /* Keep looping until finished drawing screen */
  do
   u8g.setFont(u8g_font_osb18);
   int chk = DHT.read11(DHT11_PIN);
   char dht_str[8];
   itoa(DHT.temperature,dht_str,10);
   u8g.drawStr(20, 20, "T:");
   u8g.drawStr(50, 20, dht_str);
   u8g.drawStr(80, 20, "C");</p><p>    itoa(DHT.humidity,dht_str,10);
   u8g.drawStr(20, 60, "H:");
   u8g.drawStr(50, 60, dht_str);
   u8g.drawStr(80, 60, "%");
  delay(1000);
 } while(u8g.nextPage());
Step 8: OUTPUT
Picture of OUTPUT
That's all Makers.
You have successfully completed another instructable, It takes pretty less time to create this instructable, and it's fun too.
About This Instructable
214views
7favorites
License:
Bio: Work until you no longer have to introduce yourself.
More by TheCircuit:Carrot Almond MilkshakeDIY - Flower VasePotato Stuffing - Who's Hungry
Add instructable to:
